    Aug 2005
    LOL and "snow removal" too!
    Yes the job for me! Everything I do now for less money and shoveling snow too!
    General Info
    Job Type: Full-Time
    Minimum Years of Experience Required: 5 Years
    Minimum Years of Education Required: High School/GED
    Salary Range: up to $28.66 plus fringe benefits
    Speciality: Commercial,Industrial
    Must be Authorized to Work in the US
    Company Info
    We are a 25 year old, reputable firm with 350 plus associates. Our primary focus is on Federal and state contracts. Resume responses will be kept completely confidential.
    WE ARE A GOVERNMENT CONTRACTOR AND EQUAL OPPORTUNITY EMPLOYER
    MISSION STATEMENT
    In a corporate culture of positive
    reinforcement we will produce
    excellence by continuously finding
    better ways to serve our client as we
    would wish to be served.
    VISION STATEMENT
    In a nurturing corporate climate where families
    are valued and continuous improvement is a
    way of life, we will treat our customer and our
    fellow employees as we would wish to be
    treated so that we will continue to be our
    customer’s contractor of choice.
    We provide a Drug Free Work Place and applicants subject to pre-employment drug testing. Must be able to pass Background and reference checks.
    Job Description
    HEATING, REFRIGERATION AND AIR-CONDITIONING MECHANIC
    Installs, services and repairs environmental-control systems in office, laboratory and other commercial establishments, utilizing knowledge of refrigeration theory, pipefitting and structural layout.
    Mounts compressor and condenser units using hand tools, following blueprints or engineering specifications.
    Fabricates, assembles and installs ductwork and chassis parts, using portable metalworking tools and welding equipment.
    Installs evaporator unit in chassis or in air-duct system, using hand tools.
    Cuts and bends tubing to correct length and shape, using cutting and bending equipment and tools.
    Cuts and threads pipe, using machine-threading or hand-threading equipment.
    Joins tubing or pipes to various refrigerating units by means of sleeves, couplings, or unions and solders joints using torch forming complete circuit for refrigerant,
    Installs expansion and discharge valves in circuit.
    Connects motors, compressors, temperature controls, humidity controls, and circulating ventilation fans to control panels and connects control panels to power source.
    Installs air and water filters in completed installation.
    Injects small amount of refrigerant into compressor to test systems and adds refrigerant gas to build up prescribed operating pressure.
    Observes pressure and vacuum gauges and adjusts controls to insure proper operation.
    Tests joints and connections for gas leaks using gauges, leak detectors, or soap and water solution.
    Wraps pipes in insulation batting and secures them in place.
    Replaces defective breaker controls, thermostats, switches, fuses and electrical wiring to repair installed units, using electrician’s hand tools and test equipment.
    Experience in, and the ability to troubleshoot and perform corrective measures on refrigeration and air conditioning equipment from small 1 ton AC units thru 200 ton Certrifugal compressors as well as all associated equipment.
    Ability to troubleshoot electric, DDC control systems, Metasys preferably.
    Knowledge of fire alarm sytems and data cabling.
    Perform snow removal as needed.
    Perform work and/or duties as directed in areas other than HVAC.
    Follow established safety rules and regulations and maintain a safe and clean environment
    Maintain written and electronic records, document actions and present written progress reports
    Must be able to climb ladders (step, extension, straight, etc) up to 40 ft;
    Must be able to lift and manipulate objects of up to 80 lbs for 20 ft if required;
    Must be able to bend, stoop, kneel as needed.
    Must be able to wear Personal Protective Equipment such as, but not limited to, gloves, harnesses, respirators, hardhats, protective clothing if required.
    In general, the work of the HVAC Mechanic requires rounded training and experience usually acquired through a formal apprenticeship or equivalent training and experience.
    Benefits
    Medical Insurance
    Dental Insurance
    Life Insurance
    Retirement Beneift
    Disability Insurance
    Minorities and Women encouraged to apply.
    Equal Opportunity Employer
    eventu rerum stolidi didicere magistro
    Oct 2012
    Where we mow our own grass
    I just saw a job like that for the county courthouse where I live. your job sounds better, their salary range was only like 18-24/hour.
    Jun 2009
    Alberta, Canada
    they're talking about removing snows from RTUs
    Have tools and gauges, will travel.
    RIDGID|YELLOW JACKET|UEI|TESTO|STANLEY|CPS|VETO| KLEIN|MILWAUKEE|MASTERCRAFT|
