Results 14 to 18 of 18
    May 2013
    In theory, carry away oil and contaminates out of linsets and coils. Just a brand name. There are other flushing agents.
    Jun 2013
    NORTHERN
    some smell similar to Epoxy Paint thinners! DO NOT GET ON SKIN as possible: MSDS and all- it is the solvent series that quickly absorbs into you, and your-systems are affected every time; like PVC solvents---
    2)
    Some companies dual compressors for 2 and 3 staging are linked with a parallel line at ~ 3" off the flooring/pan-
    and T-offed ports that are easily opened in operation (a little open) .
    When opened, then excess oil blows out [hoes or foams into a cup] to level (deMini's) - done.
    any recommended impervious hand protection and eye protection required
    and it works perfectly well to achieve a 'right-level'
    -wait 'til you have to silver solder one of these flare-ports to a can... tilting down as you drill, saving chips with a magnet, cleaning and closing... missing the motor windings ~ 3/3" away inside.-- when the OEM replacement compressor did not have the port assembled !
    quite odly---if it were ever super critical, -could port any can for oil-leveling- virtually hand-turning drill once piercing the can.
    Process cooling: NO COMPRESSORS Earth-Coupled since 1996
    ... however, much still needs to be hybridized energy transfer.
    CLOSED LOOP 2015 listed EER's
    even 49+ now; and "blended from low to high variable speeds" for 32deg.F ~ E-Star
    Perhaps you need a 32F Chiller/HW-Heat: buy a GEO-T Heat Pump (GHP with Heat-Recovery)
    http://www.energystar.gov/index.cfm?...mal_heat_pumps
    http://www.hydro-temp.com/products.html and Bosch/Carrier and AquasystemsInc.com
    Jun 2013
    NORTHERN
Size:  25.9 KBName:  HT Pic 1 HW sm.JPG
    cleaned and primed painted black for corrosion protection
    common to a few OEM's as with dual-compressor 3-staging annually operating very much like variable VFD's performance (-eh?) for the past 3 decades, in the field
    May 2013
    Now that sounds like a lot of trouble! I wouldn't want to be the guy to drill that hole...
    Jun 2013
    NORTHERN
    DRILL that geothermal heat pump hole in a compressor !!
    Quote Originally Posted by Rheeman View Post
    Yep:
    'twas what I got four 'following my heart'
