Results 1 to 13 of 18
    Jun 2013
    Fremont OH.
    how do i to remove exess oil?
    what is the best way to remove exess oil in a hermetically sealed system?
    Apr 2012
    winnipeg
    dump the compressor upside down...what makes you think you have excess oil
    May 2013
    How did you determine that you have excess oil in the system?
    Jun 2013
    Fremont OH.
    hypothetical question. would a system with multiple compressor replacements leave exess oil?
    May 2013
    Use a flushing agent like rx11. When changing your compressor
    Jan 2010
    Quote Originally Posted by rhumbard View Post
    If you had oil return issues.
    Oct 2011
    Chicagoland Area
    I have never done this but I've heard it's the "right" way to prevent too much oil. When you pull out the old pump, dump the oil and measure it. then remove the difference from the new pump.
    Chicago, IL
    Quote Originally Posted by Rheeman View Post
    I think I'd rather have the excess oil
    Tucson, Az
    We remove excess oil through the service port of the oil reservoir after the oil separator.
    Normally, from what I see, there are oil return problems and "technicians" add oil here and there.
    When the actual problem is repaired, excess oil must be removed.
    Do you have more specifics about the equipment you are repairing?
    Jim
    Tucson, Az
    Keeping the Ice Cream Frozen!
    May 2013
    What size of system are you referring to?
    obviously you are referring to a larger capacity system, where a 2sac is referring to a much smaller capacity unit. What capacity is the system that original post is from?
    Jun 2013
    Fremont OH.
    I'm not. I'm just wondering in case I run in to this kind of situation.
    Yep.
    I've seen this on various mini-split units.
    Blow the lines and linesets out before installing the compressor.
