Results 1 to 8 of 8
    Jul 2013
    Having a 8.5 ton unit installed and have some ?'s
    New to the forum so "Hello to every one"
    I am getting some quotes to have an 8.5ton a/c unit installed and wanted to better understand the need for large ducting.
    In one of our other buildings which is much larger there is 12" ducting running from 3 different a/c units. which are cooling a larger area.
    In one of my quotes the ducting is almost 3 times bigger than the 12"
    This unit is bigger than the other ones but is cooling a smaller area why do I need such large ducting? Also do I need as big ducting for the return? lastly does it matter if the ducting is installed near the roof or could it be down low? (being the unit will be installed at ground level and the ducting will have to go through the wall.)
    Oct 2010
    8.5 tons requires large duct, that's ~3400cfm of air flow. Probably somewhere in the 32-36" diameter round duct.
    12" metal pipe is good for about 1/2 ton worth of airflow. So if you were running 12" pipe for a 8.5 ton, you'd need about 17 runs!
    Southold, NY
    Minimum
    Jul 2013
    Quote Originally Posted by jtrammel View Post
    So the return Would have to be the same size as well?
    Oct 2010
    Quote Originally Posted by eroc View Post
    Or slightly larger.
    Dec 2000
    Flat Rock, NC
    With duct size answers like this who do you get approved to reply to AOP questions?
    S.E. Pa
    Quote Originally Posted by codgy View Post
    This is the Ask Our Pro's or AOP forum. In order to post responses here, you must have verified qualifications and have been approved by the AOP Committee. Please see my signature line for links to register and review the AOP Forum Rules. Thank you.
