Results 1 to 13 of 13
Thread: Paragon 8141-0b??
04-13-2007, 07:00 PM #1
- Apr 2002
- 61
Paragon 8141-0b??
did paragon change this model # i was at the disti and he gave me a weird model to replace this.
it's a 220v defrost timer.... time start / time termination
04-13-2007, 07:17 PM #2
Describe weird?
04-13-2007, 07:23 PM #3
- Apr 2002
- 61
I don't really remember.......i looked up online seems like the replacement should be an 8141-20 does that seem correct
04-13-2007, 07:32 PM #4
8141 is the Model #
-10 is 110V
-20 is 220V
04-13-2007, 08:41 PM #5
04-13-2007, 09:01 PM #6
- Mar 2007
- Orange County NY
- 211
Last month my distributer had the Paragon saleman there while I picking up materials, he had a new electronic time clock he was demoing don't remember the model #. It replaces most timeclocks-setup via dip switch.
04-13-2007, 09:50 PM #7
- Aug 2006
- 442
04-13-2007, 09:52 PM #8
- Aug 2006
- 442
04-14-2007, 04:35 PM #9
04-14-2007, 06:59 PM #10
Member
- Feb 2004
- Kansas
- 18
We have switch to a time clock made by Grasslin that replaces all the Paragon models, it is dual voltage. Even has a light indicating whether it is in defrost or refrig. mode.
04-14-2007, 07:07 PM #11
Member
- Feb 2004
- Kansas
- 18
04-14-2007, 08:03 PM #12
- Feb 2007
- 28
the 'b' on your # only indicates it was originally bracket mounted, not in its own case as the replacement comes in -- sometimes maufacturers sell only the timer assembly, without the box -- they mark those with a 'b'
the grasslin universal timer is a great clock for setup, and does replace many types, but i had one blow up in a building with erratic power problems, so make sure you ue it in a place where voltage to it is always steady, no spikes, brownouts, etc
06-20-2008, 12:07 AM #13
Once I shorted a wire on the roof by mistake.The Grasslin solder contact blew before the braker tripped .I had to replace it for no reason.I have replaced a bunch of them so far.I am not in favor of electronics in refrigeration systems.When the conderser coil gets dirty they are susceptable to failure.
