Results 1 to 13 of 16
    Jun 2007
    Jersey
    Home warranty repair
    No words picture says it all
    Any fool can know. The point is to understand. Albert Einstein
    Aug 2012
    Nice drain pan. to bad the air can't get around it.
    It's not if your doing it right it's whether your doing the right thing that is important.
    Apr 2003
    Maple Grove, MN
    What are we looking at? Did that unit used to have a different drain pan, or is that a horizontal only unit? Either way, it looks like they at least get an "F" for "Effort".
    Jan 2005
    Houston TX
    The pan is not the problem, but it is not that great either. The open vent line before the drainline trap I would say is more of the issue. As air gets sucked through the drain and prevents condensate from properly draining.-GEO
    Once in a while everything falls into place and I am able to move forward, most of the time it just falls all over the place and I can't go anywhere-GEO
    South Eastern Missouri
    That looks like an up-flow installed upside down. They added a homemade drip pan that blocks dome of the air flow. Such a sad looking unit.
    A people who would exchange liberty for apparent safety, will deserve neither and lose both.
    Nov 2011
    East Side
    it's a horizontal unit.....
    Keller, TX
    I don't get it. Where does the air leaving the blower exit the unit?
    The man who smiles when things go wrong has thought of someone to blame it on. - Robert Bloch
    Quote Originally Posted by 71CHOPS View Post
    Ahh I see it now. So use to up and down flows, I hardly ever see and horizontal units here.
    Jun 2012
    Northern NV
    Run what ya brung, eh?
    Knew one "contractor" who would buy a truckoad of whatever furnace was being remaindered and offer "special" pricing with one size fits ALL. Think shack with 140000BTU 80% FAU
    Jul 2010
    napping on the couch
    It probably was a unit that had condensate drip off the coil and onto the blower and leak out the bottom of the unit. This is sort of common on those Carrier/Bryant/Payne units. It either has a dead circuit in the coil and when the water hits the dry section as it drips down there is no capillary action so it falls off the coil. Or, sometimes it just drips off possibly due to a coating of oil or other contaminant. Hitting the coil with some harsh condenser coil cleaner fixes it.
    Those units can be mounted vertically or horizontally. There is a little plastic pan just under the coil.
    Anyway. The picture if someones bright idea how to fix it.
    “Free men do not ask permission to bear arms.”
    -Possibly said by Thomas Jefferson(but true even if he didn't)
    “What one generation tolerates, the next generation will embrace.”
    ― Definitely said by John Wesley
    "One out of 3 Democrat voters is just as stupid as the other two"
    -Said by me
    Oct 2010
    Austin, TX
    I don't think that is the original coil, is it?!? Almost looks like someone swapped out a bad coil for something else. See how it has two support bars in the original drain pan.
    If you're too "open" minded, your brains will fall out.
    Artificial intelligence is no match for natural stupidity.
    Aug 2012
    NE wisconsin
    All it needed was a cap on the drain vent so the trap would work correctly.
    Jan 2006
    McQueeney, Texas
    Must have been a new graduate from engineering school.
