Results 14 to 22 of 22
    Virginia
    moisture and oil make acid
    dont ask me how ....
    Feb 2012
    Corpus Christi
    Quote Originally Posted by Samshawn View Post
    What will cause the acid in the Compressor oil?
    Here is a good thread about what conditions lead to the formation of acid in a system.
    http://hvac-talk.com/vbb/showthread.php?t=100144
    Dec 2011
    Asheville, N.C.
    If the refrigerant in the system gets too hot, the compounds will begin to break down forming acids that will mix with the oil. If the system does not get hot enough to cause a burnout the acid stays in the system till it eats it up or is nuetrilized. Certain noncondinsables can also cause acid.
    Mar 2012
    Connecticut
    Thank you very much everyone.
    Elkhorn, Wisconsin 53121
    usually a system that was previously contaminated from a compressor burn out.
    Madison, WI
    Sure you can change the oil. If it has mineral oil in it change it to an equal amount of polyolester oil and mark it well. Then in the future if R-22 gets crazy expensive you can use R-407C which is the recommended replacement for Copeland products.
    Some folks say you have to get every drop of mineral out or you will contaminate the polyolester...Not true, just dump as much out as you can and refill with equal amount.
    Of course if you had acid or water in the system you still have to add suction and liquid line driers to treat the oil that is out in the system.
    Cleveland, OH
    I used to have one of these, it works as advertised:
    http://www.nucalgon.com/assets/prodlit/3-78.pdf
    Good? Bad? I'm the guy with the gun.
    Statements made by me are strictly my opinions and do not reflect the opinions of my employer. I am not authorized to make any official statements on behalf of my employer.
    Any technical advice offered by me is for educational purposes only, all HVAC related repairs should only be attempted by qualified personnel.
    Mar 2016
    help
    because the compressor is bad.
    Mar 2015
    ARK.
    Simple introduction of,
    AIR.
    Hydrogen,Oxygen+Chlorine=Disaster.
    Simple but deadly.
    No matter how long you have been doing this,
    Go back and reread the Basic's.You WILL Learn something.
    Why is it called,an Act of GOD when IT has Nothing to do with Him?
    Will of the Devil would be more appropriate IMO.Just Saying.
    PSALMS, 18 & 25.
    I am Tired of High Efficiency Propaganda.
