Results 1 to 13 of 29
    Jul 2013
    Replaced condenser fan with higher-CFM model.
    Hi all,
    I own a cheap (no manufacturer name even) Red Bull merchandizing cooler that I use as a fermentation chamber for homebrewing beer. I have it wired with a Ranco digital thermostat for precision temperature control, and the fridge sees a very light duty cycle due to the fact that beer fermentation happens between 50 and 70F.
    Last week, the condenser fan assembly (120x120x38mm, .2A @ 115V, 71CFM) started making a bad racket due to the bearings failing. I got a replacement fan assembly, but I got one with 105CFM airflow because that was the part I could easily locate in town. I checked the wiring to make sure it could sustain the extra amps, so I'm good on that end.
    Here's my question:
    Is upping the CFM of the condenser fan going to put undue stress on the compressor or any other part of the system, due to enhanced heat exchange at the condenser?
    I read over the DIY rules for the site and I think this question is within-bounds, but I apologize in advance if I've actually broken the rules.
    May 2003
    Utah
    Let's see...replace failed part with new part that has different specifications and then ask qualified technicians if there is a problem with this...
    Versus...
    Hiring qualified tech to do the work.
    Jul 2013
    Frown
    Quote Originally Posted by bunny View Post
    Versus...
    Hey man, you can lose the snark.
    I just asked a straightforward question in a polite manner.
    Forget about it, anyway. I got an answer from someone else.
    Oct 2008
    Quote Originally Posted by marinosr View Post
    URBAN DICTIONARY:
    snark noun
    Combination of "snide" and "remark". Sarcastic comment(s).
    Also snarky (adj.) and snarkily (adv.)
    Well HE came in with his guns loaded.
    SEE-YA - A - A - A - a . . . . . . .
    Southeastern Pa
    Please refrain from allowing the portal closure to impact your posterior....
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Colorado
    If he understood all the different characters and equipment we have to deal with day in and day out, not to mention the miracles we are expected to perform for the least $$ amount, he would be full of snark too....
    Jun 2013
    Atlanta, GA
    My dogs name is Snarky, come to think of it, my mother-in-law has been a little snarky lately..........
    Mar 2013
    Lmao. The coil is going to freeze up and he'll be back on here asking why CFM effected what's going on inside the box. Good OL consumer 'save a buck' mentality.
    Mar 2013
    swan valley idaho
    And then he won't tell the new tech he finally calls the fan is wrong, which will cause him to spend more time than necessary, which will cost him more money after all......
    DIY and save!
    May 2003
    Utah
    Laughing' my snarkin rear off.
    California
    When I was younger, I used to watch The Snorks.
    Are Snarks anything like Snorks?
    Jun 2013
    NORTHERN
    OEM Herm Cans to semi ? today? right cdsr spec.....
    Hey B :
    in that avt pic of yours, are the 15 to 25 t tin can hermetics/ recips or scrolls holding as well as the semi in any professional chillin' ?
    I will use either the OEM cdsr fan condition DX-cfm specified; or water-cooled-hybrid-to-dry-cooler-Earth-Coupled-Ground-Loop-GlobalThermaXchange(GTX(tm)) connected exchange system , OEM of course...
    How are the cans holding up?
    I have constant duty "chillers" making HW since 1981 and used for chilled-W:cooling/ HW: space-heating to a same 7.1/2ton air coil, a HW tank, and a 5T tube-in-shell flooded evap HX as well on Erie 3way hydronic valve automation, outlasting bronze circulators that failed in 26 years.
    But these cans are only up to 4.tons on the hermetic label.
    Process cooling: NO COMPRESSORS Earth-Coupled since 1996
    ... however, much still needs to be hybridized energy transfer.
    CLOSED LOOP 2015 listed EER's
    even 49+ now; and "blended from low to high variable speeds" for 32deg.F ~ E-Star
    Perhaps you need a 32F Chiller/HW-Heat: buy a GEO-T Heat Pump (GHP with Heat-Recovery)
    http://www.energystar.gov/index.cfm?...mal_heat_pumps
    http://www.hydro-temp.com/products.html and Bosch/Carrier and AquasystemsInc.com
    Jun 2013
    Austin, TX
    More airflow should not cause a problem. The compressor will not be working as hard. Whether the efficiency goes up or down depends on many factors, but it's unlikely to be significant. It will slightly increase the minimum operating temperature, but a low ambient control will fix that.
