Results 14 to 26 of 29
    Jul 2013
    If at Tap 1 still too high, how can one increase static to get lower CFM?
    Jul 2013
    Also, the return intake was reduced to a grill with 15.5 x 15.5 insertable filter - AHU has 20 x20 intake /filter but couldnt be used access given the space limitations.
    Upflow unit with bottom intake - old unit was upflow with side intake. they created mini plenum under unit and installed fo return. Its in a closet.
    Jul 2013
    they created mini plenum under unit and installed the grill for return. Its in a closet.
    Mar 2006
    The South
    It appears you are at lowest setting which is good. That high RH concerns me though. You might consider a cheap digital hygrometer for measuring humidity. I would want to know before I asked dealer to exchange for 2 ton condenser. Blower fan set to auto at thermostat?
    IMO
    Jul 2013
    Thanks. I am using inexpensive digital hygrometer to measure RH. Blower is set to Auto. Is there a way to increase static pressure to further lower CFM without creating noise/coil performance issue?
    If I can get the noise/CFM down that would be a good start. Again, I appreciate all of your time.
    Mar 2006
    The South
    What's outside temperature now? And what kind of runtimes are you getting at the moment.
    What is RH outside and inside? Keep a record and share with dealer. He might give you some suggestions.
    I am not a believer in jury rigging or artificial manipulation. Don't want to do anything that might hurt system and jeopardize warranty especially on a forum like this.
    mO
    Jul 2013
    Right now its 94 RH43 - inside 75 RH50 (digital hygro) roughly 10 minute cycles. I would not do anything by myself, the dealer would do any changes. I too am not a fan of jury rigging. I will keep a log and discuss with contractor. Thanks, thanks and thanks. Have a great one.
    Mar 2006
    The South
    Keep us posted...
    Dec 2010
    On a Peninsula in NE NC
    May have to much static pressure now with only a 14x14 return basically. Remove filter while running and see if you don't notice a differance.
    Jul 2013
    I will try that but I assume I will get even more CFM when I think I need less.
    Will let you know.
    Jul 2013
    I pulled filter and got a slight reduction in noise at the AHU intake but not much other noticeable effect. Still have strong "winds" - noise at registers.
    Cycle time unaffected. Im really starting to think the whole system has to be replaced. Just swapping out compressor to 2 ton may create more problems than it solves.
    At a minimum sounds like Im getting too much air for ducts.
    I welcome all thoughts and comments.
    Thanks to all
    Jul 2013
    CORRECTION: ONLY OPTION IS TO SWAP COMPRESSOR OR SWAP BOTH COMPRESSOR AND AHU.
    I ORIGINALLY THOUGHT IT WAS POSSIBLE TO SWAP AHU ONLY BUT THERE IS NO AHRI REFERENCE NUMBER FOR THIS 2.5 TON COMPRESSOR TO BE MATCHED WITH A 2 TON FIXED SPEED AHU
    WITH THIS MFG. THANKS
    Dec 2010
    Quote Originally Posted by HPQ View Post
    Thanks to all
    My point with this and for example my own house. Second floor 1.5 ton in a closet on a pedestal box just like yours. At first I just had a 14x14 grill with a filter and that is all. The unit was a tornado of wind. I recently cut oout to 18x18 and now I can not even here it run.
