Results 1 to 8 of 8
    Jul 2013
    Help with choosing a thermostat
    I recently purchased a remodeled home that has new central heat and air installed. I need a new thermostat for various reasons. I'm out of town usually weekdays but my schedule can vary at times so I definitely need a programmable thermostat and one with wifi support preferably so if i am gone for an extended stay that is unplanned I can change my thermostat from my phone or computer. Now my dilemma is like many home owners in that my home has an upstairs that is generally warmer than the downstairs. The home is well insulated with r19 in the walls (they are an oddball wall at around 2x7). Overhead is blown in and windows are all new. I would like a thermostat that will support a wireless thermostat I can put upstairs and will either average out the temperatures or will let one over ride the other when the upstairs is above a set temperature. Also I'm looking into retrofit zone systems so I'd like a thermostat that can support that. Any help choosing a thermostat would be appreciated and also some info on these retrofit zone systems in case the remote sensor doesn't help the problem enough. Thanks.
    -Derek
    The Laws of Physics are pretty well in place, warm air rises. Air like water tends to flow in the path of least resistance. So that is what you strategy is up against. There are several zone systems that can allow you to add a damper if what you need is simple upstairs, downstairs control of the airflow in your home. I would suggest however that you call your HVAC contractor and ask them to evaluate your current system. Airflow is simple in concept, but the application of technology can be tricky. You also need to be aware of the return air requirements for your system. The important thing about picking a zoning system, Identify your use pattern and decide what rooms can be served together. If you do that, your conversation with your contractor will start off on a better note, and he will know that your priority is to build more control comfort in your home, not just apply thermostat technology.
    The choice of a thermostat is getting more complicated. I can tell you I use the Ecobee system and have found it to be feature rich and "fairly easy" to learn. I have seen the Nest product used successfully, and there are many other models out there depending on what you want for a dashboard and your budget. Make sure you need the bells & whistles you are paying for. I really don't go to my thermostat for a weather report...
    Aug 2013
    This is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise, commentary, or ask questions of the OP here.
    Further infractions may result in loss of posting privileges.
    Athens, Ohio
    I like the Honeywell Prestige. We use it at home and our customers rave about it, too. You'll need to get a Red-link Gateway for wifi use, but the app and use of it are free.
    We have a Portable Comfort Control that we can move to different areas of the house.
    As for the warmer upstairs situation, you need air circulation up there. Zoning is the best solution but you'll need a dedicated duct to that level. It may involve considerable expense.
    I usually advise customers to turn the thermostat fan switch to "on" to circulate air constantly. That will reduce the temperature difference between floors but it also causes moisture on the coil at the end of a cooling cycle to be evaporated back into the air.
    A variable speed motor for the furnace will use a lower blower speed for fan only cycles. It is more comfortable than high blower speed .
    I have a new Prestige and it is constantly reporting receiving faults from my heat pump. Trouble is, I don't have a fault signal from my heat pump hooked up. Driving me crazy, Honeywell has no idea what's up. But generally I'd trust Honeywell over many of the others. Nests have been good for biz, mostly since they have a lousy manual and lousy tech support in my experience. We've put in 1 Ecobee. I set it up with the equipment, it was up to the HO to get it online. I imagine he did.
    TennesseePhil, this is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise, commentary or ask questions of the OP here.
    Your post has been deleted.
    Jun 2006
    SW MO.
    Sounds like you would be a good candidate for a Nest thermostat.
    http://nest.com/inside-and-out/
    Athens, Ohio
    Quote Originally Posted by chaard View Post
    How can you tell he drives a Prius?
