Results 1 to 7 of 7
    Jul 2013
    Window Unit to compensate for dehumidifier
    Hello all:
    I have a ~900 sqft basement that I use a 50-pint dehumidifier to remove excess moisture with. We live up in north central PA. The problem is that the unit heats the basement to ~77F in the summer which is a bit hot for my wife. I was thinking of installing a 6-8,000 BTU window unit in an above grade window (south facing unfortunately). Any thoughts or should I do something else?
    Thanks for your assistance!
    Steve
    Quote Originally Posted by Ponchopka View Post
    Hello all:
    Steve
    It would serve the same purpose and reject the heat outside
    Jul 2000
    Northern Wisconsin
    It will do what you're trying to accomplish... reduce the temperature in the basement. An added bonus is it will help reduce the humidity also.
    If you're having enough moisture/humidity in the basement to require the dehumidifier to run enough to overheat the basement you might want to try and reduce the amount of humidity that needs removing.
    Jul 2013
    Thanks - would 6,000 be sufficient or should I go with 8,000? I don't want to over size the unit but since the cooling requirements are so low I also don't want to undersized the unit...
    Jul 2000
    Northern Wisconsin
    The energy/btu's the dehumidifier is putting into the basement (not exact) is easy to figure out. Look at the name plate and look for the line that says one of the following: Amps/amp draw/wattage.
    Assuming a 110VAC unit.
    Amps x 110 = watts consumed by unit. Watts x 3.41 = btu's the unit is basically putting into your basement.
    Jul 2013
    Ok - so at 5.2 amps and 115 volts we are talking about ~ 2040 BTU. So it sounds like a 6,000 BTU window unit would be more then enough...
    Madison, WI/Cape Coral, FL
    Hello all:
    Steve
    Your dehumidifier may not be operating properly. How much moisture is the unit removing per day? Some dehus remove very small amounts of moisture while using a lot of electricity. Results are a warm basement before getting dry.
    Dehumidifiers like Santa Fe Compact dehumidifier will remove 7 gals. of moisture per day which quickly drys the space and the dehu starts cycling. Get a good dehu and forget the a/c for basement space. I would expect a Santa Fe to warm a basement 3-4^F and maintain <50%RH. This would cost $15 /month verses +$50 per month for a/c and dehu.
    Regards TB
    http://santa-fe-products.com/index.p...d=61&Itemid=36
