Results 14 to 16 of 16
    Madison, WI/Cape Coral, FL
    If the %RH in your home is <50%RH, you will freeze at 68^F. Check your %RH and temp to help us comment on your settings. Also what is the supply air temp/%RH? It is possible that the cooling coil is not very cold. Most occpants and equipment mfgs suggest 70^F, 50%RH is a minimum temp.
    Looking forward to your post.
    Regards TB
    Jul 2013
    Here is what the house was sitting at this afternoon.
    Quote Originally Posted by Beachsled View Post
    I dont think we would ever set the indoor temp lover then 18'C. I guess I will have to look into some of these other controls so we can have the house at 20'C over night even if the outdoor temps dip down to 10-15'C.
    Thanks guys
    Might want to look into an economizer.
