    Jan 2013
    Dyersburg, TN
    Factory start ups
    Does Carrier or other manufactures use outside contractors for startup and warranty repair?
    East of big city prices.
    What type of equipment are you talking about?
    Somewhere in the world.
    When I worked for the OEM not Carrier if we did the start up the warrenty was valid unless we found something wrong with the installation which we could have the power to void the warrenty based on the installation , most contractors did pay for the start up on on any pieces of equipment but there were a few that wanted to do it themself which most likely did have some concerns when somebody wanted to have something covered under warrenty I am sure that they would have had to have all the proper documents to prove that everything was done properly and up to specification.
    A mind is like a parachute. It doesn't work if it is not open.
    The best part of going to work is coming back home at the end of the day.
    Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all.
    Jan 2013
    Dyersburg, TN
    Carrier mainly and a maybe Trane. I know on carrier and Trane if u have factory startup the warranty is better. I would like to be able to startup carrier (mainly) and have the same warranty as if a factory rep started it up. I am a FAD dealer for carrier. It could get me a lot of work if I could startup carrier and have the same perks as factory? Thanks
    Jul 2013
    Illinois
    This is something you should think long and hard with, I think you can order chillers without factory startup, the warranty could be voided, equipment today is becoming very high tech from everything from mag bearings, electronic xv's, programing, critical charge amounts, oil management, the point I am trying to make is do you think the rewards out way the risks. I have been seeing more and more issues found at start ups that if it were not seen by properly trained techs could have done high dollar damages, one bad job could wipe out all gains for a long time, think very hard on the risks evolved. The area you may want to focus on is in performing the preventive maintenance, just understand the tasks and methods and document very very well.
