Results 1 to 4 of 4
    Oct 2011
    Gladstone, Oregon (Portland)
    Lifebreath HRV anyone?
    Don't see any HRV's posted too often. This one is in a garage....pick it apart.
    And a furnace installed buy a colleague. I did the drain and insulating only.
    Oct 2011
    Why are they sideways now.... Someone fix please.
    May 2012
    Upper Michigan
    I've heard of horizontal furnaces but a horizontal water heater is new!
    Jun 2012
    Northern NV
    155 or 200?
    I see you are returning to the furnace ahead of the air filter. Assume the stale air is coming from the bath rooms? In any case, it is a must that you follow the mfg's instructions on balancing the system. Does the HRV run with the FAU or independently on demand from the baths? If independently, balancing will be a bugger. Gotta pick which condition makes more sense.
    I typically returned the fresh air back into the house in the closets, which generally benefit from the fresh air with lower humidity and cooler air gets tempered.
    HRV's are great technology when applied properly. Learn and earn! Become the expert and sell em! Lifebreath has some good educational materials, just ask 'em.
