Results 14 to 26 of 36
    Jul 2013
    Las Vegas, NV
    In Europe and Japan Daikin is considered the best brand, and they have only mini-splits. I don't know how Daikin aquisition of Goodman will affect the quality, but to me you can not go wrong with Daikin
    Oct 2010
    Daikan minis are nice, equal to Mitsubishi IMO.
    IRELAND
    A lot of daikins in around europe if you look up a particular european forum you should find all you need to know,cant comment myself as have not worked on many of them
    Daikin is in the top 3 in quality.......and price.
    I've worked with more of their VRV systems than the mini splits. The only issues have been installation induced.
    Quote Originally Posted by geoLV View Post
    And full blown commercial VRV systems, and ducted inverter drive systems with a conventional air handler, and the Altherma water heating/hydro heating/cooling system, and....
    Saint Augustine, Florida, United States
    did they buy goodman?
    Atlanta GA area
    Yes, Daiken bought Goodman. Be interesting to see what changes happen to Goodman products.
    Someone said they expect to see Daiken compressors in them. I believe Daiken makes refrigerants; if they make R-410 units will probably be supplied with Daiken freon in them.
    GA-HVAC-Tech
    I thought so. Goodman here has a big push on the mini splits, figured there was a reason
    Jun 2013
    NORTHERN
    Quote Originally Posted by ga-hvac-tech View Post
    .... I can.
    Although it does not seem will be top-rated, the last three KLIMAIRE's installed at the 3 customer decisions, were flared well enough.
    Working in a metal fatigue labe, no-skiv 3500 psi, I start with just enough to not leak-- in the torque catagory.
    I also showed a corporate OEM how a PLUMBER that was a geothermal dealer of some reputable successes, tokk a nearly invisible smear of tfe blue pipe sealer to his flares every time.
    The well known OEM in hand assembling 180 deg ambient steel mill A/C units for operating mechanics in 'cokpit' driver's seats uses less leaklock - brittlizing (sp) more than the tfe smear pipe dope.
    AGAIN - barely visible, and not near enough to openings to need be a part of the evacuations---
    0 flare leak-failures, but just snug enough- to an acceptable tightness and longevity
    Process cooling: NO COMPRESSORS Earth-Coupled since 1996
    ... however, much still needs to be hybridized energy transfer.
    CLOSED LOOP 2015 listed EER's
    even 49+ now; and "blended from low to high variable speeds" for 32deg.F ~ E-Star
    Perhaps you need a 32F Chiller/HW-Heat: buy a GEO-T Heat Pump (GHP with Heat-Recovery)
    http://www.energystar.gov/index.cfm?...mal_heat_pumps
    http://www.hydro-temp.com/products.html and Bosch/Carrier and AquasystemsInc.com
    Jun 2013
    NORTHERN
    MINI's?
    of the thread:
    IF APPLICABLE ----------
    some fitting in where a mini may first be considered, one may but not really want an outdoor piece of equipment:
    As MOST contractors are seeing, as many already have successfully applied:
    Many geothermal-hp consoles with a single Energy-Star(tm) sized [performance contract guaranteed] loops outside, a ground loop large enough--- consoles have more and less to offer over mini's; horizontal closet units; 3-Sided corner- standing consoles 2- 5 compressor tons (size 6's) and more.
    They also have HW heat recovery in small to large-instant on demand and operate 100% in cooling and some in heating modes- sharing BTUhs, then.
    zoning the refrigerant inseries off of the fancoil HVAC section in a cabinet-ed GHP --- there is a sharing with the blower, reducing fan use to allow for Chilled and HW to zone- off the system to mini-like split fan-coil locations WITHOUT purchasing additional Water:water chiller/heater GHP's.
    That feature works well in some comm apps WITHOUT Geo-T loops at all, allowing (horizontal too) "GHP" to just distribute heat-recovery to HW preheating while a space need cool/DeHum or reversing to pull heat from some space, then distribute heat for some other reason/ radiant high-mass and low, or Air distribution, etc.
    Is it just me, or do a lot of GT1980's posts read like the output from a "jargon generator"?
    Atlanta GA area
    The posts in question, to me, do not read very well... I doubt I would hire someone that talked like that to even do my yard. Seriously not professional.
    And the attitude... well that is why he is on ignore... the attitude.
    GA-HVAC-Tech
    Oct 2010
    Yep every one I read is hard to follow and makes very little sense... I don't think he's from around here.
    Jul 2013
    Harrisburg, PA
    They make perfect sense.... to someone....maybe....
