Results 14 to 19 of 19
    May 2008
    OKLAHOMA
    Why don't you jump? Go ahead and jump.....without bypassing any safeties, of course.
    Jun 2013
    Denver CO
    repeated board failures are often caused by poor grounding issues.
    Jun 2013
    Kemp, Tx
    I had that problem and it was a stuck contactor in the condenser unit
    Memphis
    Usually when the blower relays stick its in the off position. I've never run across a blower relay on a board that was stuck on.
    Life is like a jar of jalapenos. What you do today might burn your ass tomorrow.
    Dec 2011
    Twin Cities Minnesota
    Ok guys finally got back to customers and replaced board. I lost the "heat" call to the blower, great.Walked outside to write up bill,condenser is running!Go inside blowers off! WTF! I did not mention in my original post,"intermitant water under furnace". Found call for cool at Y,not at G. Replaced thermostate (explain that to customer!) problem solved,I hope!
    Mar 2009
    Southeastern US
    Intermittent water under the furnace is definitely a problem. You might check the primary drain and ensure it's not backing up, water on the board would explain why you keep having to replace it.
