Results 14 to 26 of 31
Thread: leak check
    Chapel Hill
    Quote Originally Posted by KB Cool View Post
    Maybe time to break out with dye! I hate the stuff! But, it's sometimes necessary!
    the dye?
    Aug 2008
    Hibbing, MN
    KB, why do you hate dye? Just curious. I've used it quite a bit with excellent results. Had one grocery store that I started servicing that went through hundreds of lbs of gas each year. Used U.V. Dye and located many leaks, small and large. Store hasn't needed gas for over a year. It seems to be a BIG labor saver, but if I'm doing harm to systems by using it, I'd like to know.
    Thanks,
    Steve
    Phoenix,AZ
    Quote Originally Posted by GenesisRefrig View Post
    Thanks,
    Steve
    I just don't like the mess it leaves behind. It gets in your hoses and on your hands if you don't wear nitrate gloves! But, yeah i've used it several times with excellent results!
    Jan 2006
    McQueeney, Texas
    Not the Dye!
    Never used it- but threatened to a few times.
    Aug 2008
    Hibbing, MN
    If you smear it on your hands, you can really freak out your young children with a black light after you've read them a scary story before bed.
    What do you do if grease or soot gets on your hands or hoses ?
    I'm just curious how you handle as event like that. I mean; in general. What do you do if grease or soot gets on your hands or hoses or other tools?
    PHM
    PHM
    Phoenix,AZ
    PHM
    I wipe my tools down with a rag and wash my hands! Why?
    My thought was that if you wash your hands with something (like soap or hand cleaner) when they are dirty then maybe you could wash your hands with something (like dye cleaner) when you get dye on them.
    PHM
    PHM
    Aug 2012
    Palmyra, Missouri, United States
    what is this dye cleaner you speak of. never seen it
    Dec 2011
    Grass Lake, MI
    No need to exceed 100 psi with a trace of r22. Too much pressure and you'll just blow the Big Blue away from the leak instead of generating bubbles you can see. A trace of r22 mixed with your Nitrogen will allow you to find the lead with a good quality leak detector. The H-10 mentioned earlier is by Bacharach.
    It's out in the truck - I'll have to look tomorrow - here they sell it right next to the dye.
    For one thing - after the leak is repaired then what do you do? When you come back later how do you tell an old/repaired leak site from a new and leaking leak site unless you clean the repaired area of dye? What do you use to clean off the old dye stains?
    PHM
    Quote Originally Posted by drife678 View Post
    PHM
    Oct 2011
    Chicagoland Area
    Quote Originally Posted by jpbhvac View Post
    I have heard but not seen, too much pressure on a leak check could damage the txv.
    Aug 2008
    Hibbing, MN
    I clean up old dye and spilled dye with brake cleaner from the local auto parts store. It works great and also comes in handy for cleaning up grease and dirt from other work surfaces in the course of the day. Never leave home without brake cleaner.
