Results 1 to 11 of 11
    Chapel Hill
    Heat pump thermostats
    I am working on a Goodman 3 ton heat pump and
    I notice there is a B port and O port for heat pump t-stat.
    I know that O will be energized the 3 ways reversing valve during cooling mode. Does B work the other way around? which B will energized during heat mode??
    Is all reversing valve work the same way, which only energized during cooling mode?
    Virginia
    yes b energizes the rv in heat mode mainly ruud/rheem
    Go Trump
    Jul 2013
    Harrisburg, PA
    Depends on the manufacturer. Rheem, Ruud, and their subdivisions were notorious for the reversing valve energizing in heating. I think they've switched and pretty much any new heat pump reversing valve energizes in cooling, which is the "O" terminal. The "B" terminal was used on older stats for energizing in heat. Now, pretty much all stats give you the option of how the reversing valve energizes in the installer options.
    Chapel Hill
    Thanks guy.
    Myrtle Beach, SC
    Last Ruud unit I worked on still energized the reversing valve in heat. Rheem too.
    Remember, Air Conditioning begins with AIR.
    Jun 2001
    Quote Originally Posted by Kevin O'Neill View Post
    +1, I have yet to run into a Rheem/Ruud that energizes in cool.
    Jul 2013
    ive got a question very similar to this. installed a new comfortsense tstat with new lennox heat pump and air handler. reversing valve wouldnt energize ( allow cooling). i double checked wiring and programming and didnt find anything wrong. condemned tstat and replaced with same thing, all seems to work fine
    but here is the kicker. very next week did essentially same system changeout and it does same deal. am i missing something obvious or did i find two bad tstats in a row?
    May 2008
    OKLAHOMA
    Somewhere a jumper may need clipped...
    Jun 2009
    South Carolina
    Quote Originally Posted by 54regcab View Post
    x2 weatherking also
    Also some of the older amana models energized in heat. I think.
    Jul 2013
    Harrisburg, PA
    Quote Originally Posted by klee7013 View Post
    x2 weatherking also
    I found out about weathering the hard way haha! They're a sub company of rheem/ruud I think?
    Jun 2001
    Quote Originally Posted by CoolShowers View Post
    Also Thermalzone and a few others.
