Thread: Fireplace odor
    Question Fireplace odor
    I have removed my wood burning insert from my fireplace and I now have a really bad smell in my fireplace. Any suggestion on how to get rid of this smell?
    May 2005
    Madison, WI
    creosote smell? Maybe the chimney needs to be cleaned?
    St Louis, Missouri
    I had that in an old house I remodeled. In that case it was a very dirty chimney ...maybe yours too, I don't know?
    S.E. Pa
    Smile insepction and glaze removal
    You said you removed the insert stove but you didn't mention a stainless steel liner, which is required. If the stove was properly installed, the odors would have gone out with the liner. If this was a "slammer" insert without a liner, I'll bet it is full of 3rd degree glazed creosote, which is a severe fire hazard as well as carcinogenic. Call a sweep and tell him it probably needs a "glaze removal". Around Philly, this costs about $800-1,200 in addition to the base price of the sweeping & inspection. Tell the sweep you pulled the stove and you need a "Level II inspection.". That will determine if the fireplace is suitable to burn wood or just shut it down.
    you can find a trained, Certified Fireplace Inspector at: www.F-I-R-E-Service.com
