Results 1 to 13 of 21
    Chapel Hill
    condenser fan motor
    hello guy, i have a service call today.
    i found out the condenser fan is turning the other way around.
    I checked the fan capacitor which it is also bad. After i replace a new capacitor , the fan motor still turning the other way around.
    I have no choice but replace the fan motor.
    Have anyone seem the same situation? Can the motor still turn without capacitor?
    Jan 2005
    Massachusetts
    Cap wired wrong or motor is reversible and wired wrong
    Chapel Hill
    it is a one way turning fan motor.
    there is only two wires go to the fan motor capacitor
    May 2011
    Western, KY
    Are you sure one of those wires was the start winding?
    Dec 2008
    Buffalo NY
    Try switching your wires.
    Sent from my iPhone 4s
    using Tapatalk
    Join http://scopeny.org/ Shooter’s Committee on Political Education
    The world is full of sheep,try not to join the flock.
    Support the Skilled Trades, Don't DIY
    Chapel Hill
    Quote Originally Posted by mason View Post
    Two brown wires to capacitor and two wires to the contactor
    Chapel Hill
    Switch which two wires? the two wires for 220v?
    Jan 2013
    had a bad wire connections cause of and go backwards on me one time
    VA
    Quote Originally Posted by jcrew4242 View Post
    Is it connected to a dual run cap or separate fan cap? Are those the only two wires on the cap?
    "The only true wisdom is in knowing you know nothing" Socrates
    Visit us at Dr. Degree°s HVAC
    or like us on Facebook
    May 2011
    Western, KY
    Sounds right, usually on 4 wire set ups the cap wires are brown or one is brown with a white stripe.
    Did you ohm the windings?
    Chapel Hill
    No, i did not ohm the motor, but after i replace a new fan motor. everything is back to normal.
    May 2011
    Western, KY
    If you still have it try ohming the windings I bet there is something weird with the windings.
    Chapel Hill
    ohm all 4 wires? what is the ohm going to help me with the problem?
