Results 14 to 17 of 17
    Myrtle Beach, SC
    Quote Originally Posted by acguytx View Post
    x3
    45% and flux is over kill( that is used for true solid brass/stainless) and 15 stay-silv/silfoss etc etc is all you need NO FLUX but pull valve caps, shroeder cores, a good wet rag over valves plus a good oxy/acet rig with good hot heat go fast and true then pour water over repair area immediately after your done.. check for leaks with Nitro, 250 for 22 and 400 plus for 410, and your golden..
    On copper to copper, no flux is needed with 15% silver solder.
    On copper to brass, per manufacturers instructions, 15% silver solder is ok, but flux must be used.
    Remember, Air Conditioning begins with AIR.
    Jun 2002
    Dacula, GA
    Quote Originally Posted by hvacvegas View Post
    It's not brass.
    but, for the goodman condenser your installing, dynaflow.
    You got that right. Dynaflow works just as well (almost identical temperature range) as 15% silphos and at half the price. Thank you very much
    Sen. Barry Goldwater
    Nov 2008
    DFW,TX
    Quote Originally Posted by Kevin O'Neill View Post
    but a service valve on most resi and light comm units arent solid brass and ive never in 15 years used flux on these connections..i assume thats what he meant..I realize that solid brass and SS would require some 45 or higher stick and ive used the ones with flux built into the rod..
    Jul 2013
    x3
    This is “NEW INFO” From the research I’ve done indicated not to use rods with “PHOSPHORUS” when brazing copper to brass ????.
    I’ve already brazed the other sections of copper with Harris stay-silv 15%.
    We are installing a Goodman GSX and the service valve stubs looks like BRASS (was not too certain) glad I asked. And the instructions state a minimum of 2% silver and NOT TO USE FLUX.
    But if The seasoned vets say its oK to use 15% ( I have that rods) then I’m set.
    Thanks again for all the valuable tips
