Results 14 to 26 of 42
    Jun 2013
    NORTHERN
    Quote Originally Posted by bwd111 View Post
    ...guy with nate stays...
    Hey if your makin' silver jewelry,and layering pices for that classy belt buckle with raised design on a back plate:
    Use the high temp first to flow at a lower-temp-flow rate rod, later, so your buckle gets done faster!
    rem: late MLRowe, Cinti OH, -70's who grad Harvard at 44yrs old (SmCmLd), taught us with using a single #5 acetylene-only torch (non-turbo) .
    She led the 7th graders making 6 WORKING 300 rpm steam-engine pop-can paddle-boats - in 2 days, I had the privilege to assist; and see some Dad's scoff to get their boy out Sat afternoon quickly .. and others praise the kid's gains.
    oh well, it helps me when on the small stuff at a 'T' to grab my last brazing with the lower temp flow rod... and only if I want to picky-une it anyways- while not supporting something that might tear away when heated, if it were a same temp flow rate...
    Process cooling: NO COMPRESSORS Earth-Coupled since 1996
    ... however, much still needs to be hybridized energy transfer.
    CLOSED LOOP 2015 listed EER's
    even 49+ now; and "blended from low to high variable speeds" for 32deg.F ~ E-Star
    Perhaps you need a 32F Chiller/HW-Heat: buy a GEO-T Heat Pump (GHP with Heat-Recovery)
    http://www.energystar.gov/index.cfm?...mal_heat_pumps
    http://www.hydro-temp.com/products.html and Bosch/Carrier and AquasystemsInc.com
    Houston,Tx.
    Quote Originally Posted by mgenius33 View Post
    Funny thing.... Who cares? Is that info ever going to help you in the field?
    +1 +2 +3 +4 +5
    Houston,Tx.
    How much torque does it take to set a 1/4" sheet metal screw?
    Jul 2009
    new york
    let the installers worry about that. How about this way question. A temperature control is a what kind if switch? What pole and throw is it? Or very easy question or what is the effect of low and high voltage beyond the prescribed limits on a single phase hermetic compressers.
    Feb 2013
    Sonora, California, United States
    one impact
    May 2011
    Western, KY
    Quote Originally Posted by jacob-k View Post
    one impact
    Haha, exactly!
    Jul 2013
    flow and melting? Thought they meant the same thing. Question was at what temp does silver alloy begin to FLOW. I said 1,100-1300 between those temp. Correct answer was 1,400-1600. Is this correct or was the teacher wrong.
    I was always told 1500deg
    Jul 2009
    new york
    Correct was 1100-1300
    Atlanta GA area
    About that much...
    When the small impact starts to click, let go of the trigger...
    That is, except if it is a goodman cabinet... If it is a goodman... you have already stripped it...
    GA-HVAC-Tech
    Jun 2013
    NORTHERN
    what impact are you uzin?
    the new overseas screws take more than a click to get set , from my suppliers (!)
    Would depend upon on the gauge of metal.
    I'm sure someone can come up with some ridiculous situation in which it would, but the fact is, it doesn't mean anything...
    If you were a commercial plumber pipe fitter, welding oxygen lines and such, maybe it might be useful knowledge, but in routine HVAC, not so much. If instructors would focus on real world skills, there would be much better technicians in the field today...
    Just my 2˘...
    It is a funny thing if you look at the OP's response. He as well as many others do, that "melting and flow" are the same. I did not write the question, but I believe the point of it is to show the technician that even though the product is melting at the joint that it is still not flowing. How many brazing joints have you seen that look like chicken poop globules all over the outside of the fitting only to take it apart and nothing inside?
    Dec 2012
    columbus, OH
    Hey that's what I said
