    Jul 2013
    Heat Pumps + Oil heating
    My HVAC company suggested installing a (electric) heat pump as an additional heat source to cut down my astronomical oil heating cost. Oil heat would still be used as a backup, when outside temperature goes too low (Note I live in New England area). My questions are: 1) Are electric heat pumps effective in this region? (2) At what outside temperature they start to become ineffective source for heating?
    (Note I have to replace my current outside AC unit (used for cooling the indoors) anyways due to some other issue, and I am thinking of replacing with heat pump if it is worth it)
    thanks in advance for your help
    Jun 2013
    Austin, TX
    In general, heat pumps rapidly lose efficiency below freezing.
    Jul 2001
    Gold Coast of Connecticut
    But more than half your degree days are above 30 degrees.
    They work very well in the north, less than half the cost per BTU.
    Aire Serv of SW Connecticut- Gas heat, dual fuel and central a/c systems installed and serviced
Tags for this Thread
