Results 1 to 8 of 8
    Jul 2009
    new york
    Cant find info on cfm that most room ac are designed for
    Have a customer that wants a room ac what cfm are they usually designed for 300 or 400 cfm or more . And what is the two spped fan motor going to do. Will it increase the EER rating or just reduce running time
    Dec 2010
    You'll want the Btiu, not CFM, of a window unit needed for a particular space. The slower speed will de-humidify better. The higher speed (fan) is for better throw.
    Jul 2009
    new york
    Quote Originally Posted by George2 View Post
    true but was in a class and they mentioned a standard Cfm that window unit must meet
    Dec 2010
    Quote Originally Posted by bwd111 View Post
    I can't help you with that. I'm not sure why the amount of CFM would require a set "standard". It either cools or not depending on the size to the area/load.
    Jun 2001
    CFM is normally low per ton compared to central systems in order to reduce noise. Flows under 300 cfm per ton aren't uncommon.
    Jul 2011
    East coast USA
    never heard that before, most window boxes are based on room size or area. I would differently size by room size and load.
    Jul 2009
    new york
    It's 300 Cfm. Most widow units have 35 evap and run cooler and 300cfm gives you about 30 degree difference between in and out going air
    Jun 2001
    Is the 300CFM for high or low speed?
