    Nov 2007
    existing coil calculations
    Hi all
    I would like some help here to figure out how to go further
    I have a factory which have old copper pipes installed in several rooms and every room has its own coil i know the diameter of existing pipes and the total length of the coil pipes in every room
    now how can I calculate the existing coil capacity knowing the diameter and the length?
    considering a cold water supplying every coil with temperature of 12 Deg C and the insider temp needed to maintain in each of these rooms is around 37 Deg C and humidity of 50%-60%
    Aug 2001
    Mechanicsville, Virginia
    2012 ASHRAE Handbook- HVAC Systems and Equipment, Chapter 23 - Air-Cooling and Dehumidifying Coils
    http://www.techstreet.com/ashrae/products/1833349
    Nov 2007
    Quote Originally Posted by penderway View Post
    thanks I will check it
