+ Reply to Thread
Results 1 to 20 of 21
Thread: Setting t stat at 69 degrees
    Chicago
    I told customer setting the stat this low is not a practical set point.. Since these systems are not designed maintain that kind of indoor temp.. Due tightness of duct system and home..
    Feb 2013
    Cary NC
    A customer was griping that her t-stat was set to 69 and when she was cooking in her kitchen the temp would jump to like 72. HAH. This was a residence i think. Refer her to a refrigeration specialist me thinks. LOL Or she could invest in new windows with low e glass, double walls, attic and crawl encapsulation, or just a window unit in her kitchen.
    Dec 2008
    Buffalo NY
    I run mine at 68 at night when I'm sleeping. It has no issues keeping temp.
    Join http://scopeny.org/ Shooter’s Committee on Political Education
    The world is full of sheep,try not to join the flock.
    Support the Skilled Trades, Don't DIY
    Feb 2013
    Cary NC
    If money was no object I would keep mine at 68. Someone tell me how to get the degree mark.... was it alt while typing?
    Dec 2010
    On a Peninsula in NE NC
    Quote Originally Posted by Todd Whaley View Post
    Sell he a hood to suck the hot air out instead of it filling up tje house. Then add some make up air to tje ac unit. I see dollar signs.
    I'm at 68 now for sleeping. Sitting on the couch typing with no shirt and still a bit warm
    SE Ohio
    I'm typing with no pants! I win!
    Oct 2012
    Wisconsin
    I was at a restaurant with an all female kitchen staff. Thermostat set for 62* actual temperature about 65*.
    Nov 2012
    Charlotte, Michigan 48813
    Quote Originally Posted by Mike19 View Post
    If you asked them to live with 62° in the winter they'd form a lynch mob.
    Mar 2009
    Mid-Mo
    Yikes. I showed up at one the other day where they said it was hot. I walked in and they said "SEE IT'S 70 IN HERE!!! I'M HAVING THE CHANGE OF LIFE AND I'M HOT!"
    Sorry lady....regulation says setpoint is 74...
    NH
    Quote Originally Posted by qwerty hvac View Post
    Same here...
    French Settlement, Louisiana, United States
    I'm at 68 now but will drop to 66 when I go to bed. Stays in 70 all day.
  14. #14
    Jun 2013
    NORTHERN
    office 64 for firearms rehap machine shop. I made it happen of course.
    airport offices 68, and "still hot" ! and we 'moved' their heads out of the beam of overhead cutsie dutsie low volt high intensity 'mod=lite' system...
    Showing a house on a 90+ day?--- 66*f shocks them into signing!
    the 64* guy lives 62 in winter ~~~~ ! he just tolerates 64 the rest of the year.
  15. #15
    Jun 2001
    Do these people own stock inthe local electric company?
  16. #16
    Feb 2013
    Cary NC
    My bills are pretty low considering a poor envelope and old flex. Keep mine at 72° If I did a duct blaster it would be atrocious!
  17. #17
    Dec 2003
    It all depends on the system, but you can't get past the engineering and physics. 10 SEER and older equipment were typically designed to have an evaporator coil temp 35 degree colder than the air going across it. 68 degree return AT THE UNIT would equate to a 33 degree coil design temp. That doesn't account for the fudge factor of a few degrees either way, poor airflow, etc. 13 SEER and above normally have an evaporator coil temp 30 degrees colder than the entering air, so you have a little more leeway there.
    This all of course depends on system installation. If all of the returns are on the floor, and maybe the home has a basement, then your coil entering air temp will be lower than the t-stat temp by a few degrees. Add in poor airflow, and you will have problems. System freezing, slugging liquid back to the compressor, shortened lifespan.
  18. #18
    Poodle Head Mikey's Avatar
    Poodle Head Mikey is offline Membership Chair/ARP Committee / Professional Member*
    I try to stay as far away from myself as I can.
    Hold ALT and hit the zero key
    PHM
    . . . tell me how to get the degree mark.... was it alt while typing?
    PHM
    When faced with the choice between changing one's mind, and proving that there is no need to do so, most tend to get busy on the proof.
  19. #19
    Remind me again - how much did you say you weighed now? <g>
    PHM
    PHM
  20. #20
    Hell; that sounds like a Dare to me! <g>
    PHM
    Quote Originally Posted by tangogreen View Post
    . . . you can't get past the engineering and physics . . .
    PHM
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
