Page 6 of 9 FirstFirst 123456789 LastLast
Results 66 to 78 of 105
  1. #66
    Jun 2013
    NORTHERN
    So, as I understand it .,.,...... it?
    it gets me closer to that 14,000 mark !!!! hahahahahahahh!
    Process cooling: NO COMPRESSORS Earth-Coupled since 1996
    ... however, much still needs to be hybridized energy transfer.
    CLOSED LOOP 2015 listed EER's
    even 49+ now; and "blended from low to high variable speeds" for 32deg.F ~ E-Star
    Perhaps you need a 32F Chiller/HW-Heat: buy a GEO-T Heat Pump (GHP with Heat-Recovery)
    http://www.energystar.gov/index.cfm?...mal_heat_pumps
    http://www.hydro-temp.com/products.html and Bosch/Carrier and AquasystemsInc.com
  2. #67
    Jul 2009
    new york
    Quote Originally Posted by Tommyz23 View Post
    It does. Everyone wants to condemn someone for saying you'll get a high head low suction when we've all seen it (unless all we work on is package units). Type in low suction high head and see what you get on this forum. Restrictions. Very rarely do you get a perfect system like a package unit from the factory. That is when you get the lower than normal suction and head. But instead we get the 75 foot line sets, old as hell, not evacuated properly and so on and so forth. With that said, it is possible to get both. I won't lie. I've gone and hooked up my gages and said "oh it's low" and out charge in of only to see my head rise. Then say opps restriction. When it's hot hot hot and you're ****tin and gettin it happens. Hopefully you realize dumping charge in isn't the solution.
    I smashed the highside with a hammer to totally restrict highside and after 30 seconds both pressures were low. After reading this debate I never say high head pressure at all
  3. #68
    Jul 2011
    Nanaimo,BC, Canada!
    I think next time they have a meeting for reinventing the wheel we should all be on that committee ! Lol
  4. #69
    Jul 2013
    Quote Originally Posted by bwd111 View Post
    Line set length? Overcharged? It can happen is what I'm saying. I've seen both.
  5. #70
    Neginhorn optical senwish 45 ! One time a setdown happened - overage can do too. I can't see leptune happen - but sometimes; who can know mob? <g> Your furtunate planet-wise I can. Best to just charge and go or not.
    Oh! Sorry! I guess was channeling someone from 1980 there for a minute. Whew!
    PHM
    PHM
  6. #71
    Jul 2013
    Well, I thought this thread would help but its not. I'll ask it on this thread then. I have a unit. That is running 50 lb suction. 50 degrees of superheat. 475 pound head with anywhere from 8-13 degrees of subcooling. Amp draw slightly low but not sure. I was thinking it may be the TXV. It will run like this till the compressor thermals out and it will make a ticking noise on the compressor. It's a 2 year old York system. Coils are clean. We installed. Maintain them every year.
  7. #72
    Jun 2013
    NORTHERN
    PHM
    lololol hahahhah I can barely hit the keeezzzzzzz GOOD NIGHT !!!! hahahahh LOLOLOLOLL VERY- L !!!
  8. #73
    Jun 2013
    NORTHERN
    HEY phm IS GETTING CLOSER TO 14000 TOO !
    50 lb suction. 50 degrees of superheat. 475 pound head with anywhere from 8-13 degrees of subcooling. Amp draw slightly low but not sure. I was thinking it may be the TXV. It will run like this till the compressor thermals out and it will make a ticking noise on the compressor. It's a 2 year old York system--------------
    410a? more info LOADS and work to be done; or ignore if somewhere you mentioned , etc.
  9. #74
    Jul 2011
    Nanaimo,BC, Canada!
    Neginhorn optical senwish 45&#186; ! One time a setdown happened - overage can do too. I can't see leptune happen - but sometimes; who can know mob? &lt;g&gt; Your furtunate planet-wise I can. Best to just charge and go or not.
    PHM
    Pmsl
  10. #75
    Southeastern Pa
    PHM
    I think that there are two possibilities:
    1) adult beverages
    2) space aliens
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  11. #76
    Jul 2009
    new york
    Thought I called him treat head not poodle head
  12. #77
    Fill in the blanks -
    Application: _______
    Refrigerant? ______
    Air temp entering and leaving condenser? _____
    Air temp entering and leaving evap? ______
    Head press: 475 lbs
    Suction press: 50 lbs
    SSH: 50
    SC: 8-13
    PHM
    Quote Originally Posted by Rattlehead11 View Post
    PHM
  13. #78
    Jul 2013
    It's a straight ac. 410a. About 120 leaving the condenser. 81 in the evap 73 out.
