Results 1 to 8 of 8
Thread: MORE POWER!!!
    Sep 2012
    northern Ohio
    MORE POWER!!!
    have a customer that does "performance testing" once each year and "equipment evaluation" reports every few years or so. there are currently two, multi reciprocating compressor, low temp, glycol chillers that are rated at 55 and 65 ton nominal capacity respectfully. each is operated around the clock for 7 day a week production at the plant. both have consistently tested at 12 to 20 percent above their ratings and have only been off line for scheduled maintenance, and not much else. "current economic conditions" have been used as a motive to increase production across the board by 20%. I have been instructed to submit "performance enhancing modifications that can be adapted to the existing equipment to meet this objective". my first suggestion of adding two mores days to each week was not even considered and now I'm told to find a "better idea". these are 20+ year old units that have had refrigerant and oil changes made since they were built, txvs have been upgraded to electronic, and both have evaporative condensers, and sub-coolers. This is my first attempt at finding somebody that knows how to get more cooling out of a system that is already overworked.
    The Hot South
    And your question is.......???
    Add 20% more pistons...that should take of it.
    Wichita Ks
    give it a vfd at 72hz.
    time for another chiller.
    ottawa canada
    Quote Originally Posted by freonrick View Post
    And dont forget to add 20% more refrigerant seeing as the compressors will be turning faster .
    Jan 2005
    Houston TX
    Put a supercharger on it with liquid injection and lots of fans to cool the heads. If you do decide to increase speed with a VFD set to a max of 72htz, don't forget to increase the voltage at least 12%. Seriously, they are doing all they can and there ain't no more. I would think you need more compressors or as was stated before larger compressors. Sounds like a good application for a couple of Danfos mags.-GEO
    Once in a while everything falls into place and I am able to move forward, most of the time it just falls all over the place and I can't go anywhere-GEO
    May 2011
    NC Foothills
    When the existing machines scatter you can put in some bigger ones to meet the demand. I think I deal with the same customer from the sounds of it!
    Apr 2013
    Portugal
    How much is the % of EXV opening when it΄s running in max operation and the % of input power when compared to the nominal plate? If it΄s below, I΄ll say 70/80 %, you can increase the heatexchanger capacity. And ofcourse keep in mind if you will absorb more heat you also need to "free" it.
