Results 1 to 8 of 8
    Jul 2013
    A Question on Reversing Valves and Compressors.
    Firstly, I'd like to thank you for taking the time to read and potentially answer my question!
    My first question is, how exactly do reversing valves affect compressors in a 2.5 Ton heat pump system? If a reversing valve is not closing all the way properly, does it cause damage relating to the compressor? I'm green to AC units and would really appreciate your expertise to educate myself on this a little more. If a 3b/2bth sized apartment is maintaining somewhere around 80-85F even though the unit is filled with Freon, would replacing a piece such as the reversing valve have a tremendous effect on the temperature the apartment would be able to maintain or could there hypothetically be a larger problem?
    Thanks again professionals!
    Usually when a reversing valve fails, you have no cooling. So problem is most likely something else.
    Techs need to take super heat and sub cooling readings to find the real problem.
    Apr 2010
    Winnipeg,Manitoba,Canada
    This is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise, commentary, or ask questions of the OP here.
    Further infractions may result in loss of posting privileges.
    ryan79, this is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise, commentary or ask questions of the OP here.
    Your post has been deleted.
    Oct 2010
    If the reversing valve is not working then yes it would have a tremendous effect on how well the unit cooled the apartment if it was replaced.
    Apr 2010
    Last edited by beenthere; 07-09-2013 at 07:50 PM. Reason: Non Pro * member, no warning, asked about his pro member application
    ryan79. Contact the membership committee. Mods have nothing to do with it.
    Use the email address you ent your application to.
    Don't post back in this thread.
    Tucson, Az
    If a reversing valve was leaking by it would have a definite detrimental affect on the cooling capabilities of the unit BUT the only way to diagnose such a problem is for a qualified technician to troubleshoot / diagnose the actual problem.
    Jim
    Tucson, Az
    Keeping the Ice Cream Frozen!
Tags for this Thread
