Page 6 of 6 FirstFirst 123456
Results 66 to 73 of 73
  1. #66
    St Paul, minnesota
    just a stupid question, but did you put initial charge (liquid) in the high side 1st with the system off, then started compressor and throttled liquid into suction, or did you charge with the bottle upright?
  2. #67
    Jun 2011
    Seattle WA
    I can't imagine this being a refrigeration problem if the pressures remain the same up to the point of the compressor shutting off. If high and low pressure cut outs are present, the gauges would show a rise or drop in pressure leading up to the failure. Does the contactor release when the compressor shuts off? Could be something within the defrost board? Although I don't think those boards from the late 80's were very sophisticated
    America; first we fight for our freedom,
    then we make laws to take it away.
    -Alfred E Newman
  3. #68
    May 2013
    California
    Quote Originally Posted by LibertyTree View Post
    Contactor does not release when compressor shuts off. The board was replaced about a year ago, and when I was doing a routine maintenance on it, I heard it making a clicking sound but could not figure out why, and since it appeared to be running normal at the time I ignored the issue.. But I still have not had a chance to ohm out the compressor, will do tomorrow.
  4. #69
    May 2013
    California
    Yeah I added charge to liquid side, and then turned system on and throttled into suction side, but I was having problems from the first time I started throttling liquid into suction side because of how quickly the compressor was shutting off. I'm starting to think that board might be part of the problem.
  5. #70
    May 2013
    California
    Quote Originally Posted by Sicofthis View Post
    Guess I'll chime in.
    R
    S
    C
    That's as much as say in the open forums, get pro and we can really help you more.
    Thanks I'm pro now.
  6. #71
    Apr 2012
    Louisiana
    You need to make a new thread in the pro residential forum. Include all current information about the problem. I'll send you a pm for what to check for now.
    You have pm's disabled just start a new thread.
  7. #72
    May 2013
    California
    Thanks I'll repost in the PRF now. I also enabled my pm.. Also what does the star mean by professional member I noticed?
  8. #73
    Nov 2007
    Mississippi
    Star is for posting in AOP section
