Page 4 of 6 FirstFirst 123456 LastLast
Results 40 to 52 of 73
  1. #40
    May 2011
    Ripley, WV
    Quote Originally Posted by IsaiahV View Post
    Whats the app you're using? Thanks for the info!
    I'm using the Check and Charge App made by Emerson climate technologies. Its a freebie and has a reference for some of the scroll and reciprocating compressors made by Copeland.
  2. #41
    Jul 2013
    Problem resolved?
  3. #42
    May 2013
    California
    Quote Originally Posted by Tommyz23 View Post
    Problem resolved?
    After I put in the new capacitor the compressor ran for about 10 minutes before shutting off. Thats better then the 2 minutes! Amps at 11.5
  4. #43
    Virginia
    you probly got a bad compressor there ....
    just like i got a bad contactor 2 weeks ago right out the box
    it happens
    You had your meter on the load side of contactor when testing for 240 volts making sure its not dropping ?
  5. #44
    Sep 2012
    New York
    I'm not sure if I missed it but was there an Plc control? Is it so hot that the compressor is going off on high head kicking off the internal.. To check if this is happening after compressor shuts off kill power confirm power is killed and check continuity between run start common and if there open its off on overload
  6. #45
    May 2013
    California
    5lbs 10 oz in system that says 5lbs 16oz I'm using the 421a that is suppose to replace r22, but my gauges do not read 421 so i'm reading off r22
    Low side 50 degrees @ 175psi
    High side 90 degrees @ 175psi
    On my meter I'm getting 110.. so is that -20 sub cooling?
    Quote Originally Posted by AllStateTech View Post
    I'll check continuity between run, start, and common today. Thanks!
  7. #46
    Nov 2007
    Mississippi
    DIY?
  8. #47
    May 2013
    California
    DIY?
  9. #48
    Nov 2007
    Mississippi
    Is this compressor at your house?
  10. #49
    May 2013
    California
    Quote Originally Posted by socotech View Post
    No
  11. #50
    Nov 2007
    Mississippi
    Suction 175 psig?
    Liquid line 175 Psig?
  12. #51
    Nov 2007
    Mississippi
    175 psig for 421a is 98 degree saturated
  13. #52
    May 2013
    California
    Suction 175 psig?
    That doesn't make sense huh lol 75 and 175 sorry.
