Page 2 of 6 FirstFirst 123456 LastLast
Results 14 to 26 of 73
    May 2013
    California
    Quote Originally Posted by walden.raccoon View Post
    You're using A different gas? O,,o
    My fault..it's an r22 replacement
    Yes its an r22 replacement and I made sure I ran a good vacuum also
    Tallahassee, FL
    You got power problems id bet. What's the amp draw on common. Also common and run together and start only?
    Jul 2013
    Have you checked amp draw? If the other ones posts blew out, it sounds like it may have been running hot as well. Filter?
    May 2013
    California
    Filters are clean. I will hop into the attic today and check how clean the coil is. But assuming all that is good and the amp draw is too high, what could possibly be causing it?
    Nov 2007
    Mississippi
    Does this compressor have the preformed terminal connector (as found on many copeland scrolls) or is it the type that you wire each lead individually?
    If it is the preformed connector, look at your female spades closely. Sometimes they get loose and cause a bad terminal connection.
    May 2013
    California
    Quote Originally Posted by socotech View Post
    Yes its a copeland that you just basically plug in. I'll check to make sure its not loose also. Thank you for the suggestion!
    Nov 2007
    Mississippi
    Quote Originally Posted by IsaiahV View Post
    The old one still has the correct MFD
    Yes liquid line drier was replaced, and yes this unit has a txv.
    Thank you for all the replies!
    Are you sure the compressor is even pumping for two minutes? You said MFD on capacitor is correct, but did you verify with a meter?
    Nov 2007
    Mississippi
    I bet that's your problem.
    May 2013
    California
    I can only get refrigerant in when the compressor kicks on, so I'm guessing it is pumping when the compressor kicks on. If the capacitor is bad, wouldn't my compressor not kick on? Or do you think the capacitor could be affecting my amps even though it has the right mfd?
    Nov 2007
    Mississippi
    I would at least check mfd of capacitor for +-5% of rated value. I do think a weak capacitor can cause higher amp draw.
    Tallahassee, FL
    I usually seat that peckerhead with a mallet.
    May 2013
    California
    Heres a pic of the capacitor, it appears to be within range.
    Name:  Photo Jul 07, 2 28 14 PM.jpg
    Nov 2007
    Mississippi
    Yea. That's ok.
