Results 1 to 7 of 7
    Jun 2013
    Question Condensation from Central Air Conditioner?
    Is normal to have condensation from your Central Air Conditioner? The reason I ask is on furnace we have this pump that in the winter it turns on every so often and draws water from the furnace, its doing the same thing when the A/C is running? Not constantly but every so often? Is this normal?
    Madison, WI/Cape Coral, FL
    Quote Originally Posted by Tom_T View Post
    Yes
    Regards TB
    Yes. Because your A/C removes moisture from the air as it cools it.
    Jun 2013
    So the pump turning on every sso often is normal I shouldn't worry about it then? thanks
    Tallahassee, FL
    Worry about it if it stops.....then you will have a puddle
    Correct.
    Jun 2013
    Thanks for the info this puts a lot worry off my head.
