Page 1 of 4 1234 LastLast
Results 1 to 13 of 52
Thread: TXV issue?
    Jun 2013
    TXV issue?
    Went on a call today where the high pressure switch was short cycling the outdoor unit. Coil was iced up and capillaries iced cleat to TXV. Suction line iced line clear out to outdoor unit. I looked at the txv sensing bulb and it was mounted vertical with the capillary coming out of the bottom. I checked the coil paperwork and it said bulb must have capillary coming out of the top of it. Has anyone else experienced such a thing, and did flipping it over solve the issue? After I thawed the coil and switched the bulb around I fired it up and had sub cool reading of 11 deg. This was in range with manufacturers chart- within 2 deg. I would appreciate any feedback.
    Houston,Tx.
    Quote Originally Posted by bjonesplumb View Post
    To see if a valve is properly working, you really need a SH reading also.
    Jun 2013
    Superheat was 11
    Jun 2013
    I mean superheat was 16 sorry I put wrong value on last post
    Tallahassee, FL
    Was the sat temp above freezing?
    Jun 2013
    Yes
    Jan 2006
    McQueeney, Texas
    I have always been taught the tube from the bulb should always be higher than the bulb to keep the liquid in the bulb and to always keep the liquid away from the tube. I always make a rise in the tube when the bulb is mounted horizontally.
    There are always conflicting opinions, but I have never had problems doing this.
    If after you changed the bulbs position and you checked the airflow across the evaporator, and other conditions as a blower motor quitting, dirty filters and such (sticking contactor) and so on and your pressures and SC and SH are normal, I would say you found the problem- and good show on doing that. Many would have missed it.
    Jun 2013
    If the liquid migrated would that cause the txv to meter the flow improperly?
    Jan 2006
    McQueeney, Texas
    There is a varied degree of liquid in the bulb and you want as much of the liquid in contact with the suct pipe area per the position of the bulb- 4-8 o'clock or 10-2 o'clock as the manufacturer requires.
    I had a Ruud system icing up and found the bulb at 4 o'clock when it was required to be at 10 o'clock. Moving it cured the problem.
    In a vertical position, allowing the liquid to fill the tube takes away from the bulb that is in contact with the suct pipe and you will also have the top of the bulb trapped with gas instead of liquid- these two can affect it's performance so I have been advised.
    In your case this could have caused the valve not to open enough.
    Like I said- this is what I have been taught- perhaps someone has a better description.
    Bulb location won't cause the system to cycle off the high pressure switch. Unless its over charged.
    Jun 2013
    It only has the factory charge plus 3 oz for lineset , the factory charge should have been accurate right?
    Jun 2013
    I am thinking it cycled off on head pressure because the inside coil iced over because the txv malfunctioned because the bulb was upside down. Just a theory .
    When the inside coil is iced over. A large amount of the liquid refrigerant stays in the coil. Refrigerant return to the compressor is decreased, lowering head pressure.
