Results 14 to 16 of 16
    Jul 2013
    Florida
    If there is a window in the garage a window unit may help the situation after fixing some of the leakage problems.
    Madison, WI/Cape Coral, FL
    Quote Originally Posted by ctroxtell View Post
    These prices hurt to even look at most seem to be close to $1000...last year I could afford that.. this year not so much
    You need a straight simple high efficiency dehumidifier with enough capacity to handle the space with a dehumidistat that operates automatically. These a/c remove about 2 pints per KWH and are crude when it comes to dehumidification. High efficiency dehus like the Santa Fe Advance !! remove 5-6 pints per KWH and fully automatic with full defrost. This +50%saving in dehumidification cost which will save $30 per month in operating cost. Durability is the next issue.
    Long term, you will be happier with equipment designed for the job.
    None the less, keep us posted. Life is a learning experience.
    Regards TB
    Jul 2011
    Lehigh Valley, PA
    Heat it with an Anthracite coal stove. No kidding! That's what I do. The balance of my house is heated too.
