    delfield slr rt99-ss
    need some assistance unit keeps freezing up programmed in 4 defrost times,dont know what people before me have done would like some help going thru settings no cal rods just off comp and fans on any help would be appreciated
    Dec 2006
    In a Mess
    not familiar with delfield nomenclature
    what do you have and what's happening other than icing up?
    more info...
    Sig removed by mod. G-Rated site
    Southold, NY
    Are the heaters working?
    Is the clock working?
    Is the drain line clear?
    Whats you background???
    Need much more info!
    maryland
    I worked on delfield 6000xl with an identical problem and found that the unit had a air flow problem. There is skid plate next to the evaporator. if the customer accident bumped the unit, this plate will move causing a restriction of convection heat. You might want to check on the unit you are working on?
    Note: Delfield should have secure this plate
    IceMonster
    NJ
    Quote Originally Posted by IceMonster View Post
    IceMonster
    Your name sounds like icemeister.I hope your posts will sound like his too.Welcome to this forum.
