Results 14 to 15 of 15
    Sep 2003
    Good Luck
    We have a lot of these homes in NE Ohio using the attic as a add on bedroom
    With the attic bedroom the existing system is usually unable to overcome the heat load
    and the easy option is it's own a/c
    They do make a/c window units for sliding/casement windows
    This is just an example of a website
    http://www.ajmadison.com/b.php/Windo...996+4294826588
    Aug 2011
    Kingston, Ontario
    Quote Originally Posted by small change View Post
    Good Luck
    I have been offered a window a/c - not meant for sliders, but I can probably add a removable plywood cover on the inside of the window frame to support it. It will have to be removed in the winter and re-installed each year. It will also likely be noisy. But it is free, so I may try it.
    Better insulation, better attic ventilation and higher blower circulation may offer e a more elegant solution But no doubt more costly!
