Results 1 to 7 of 7
    Jun 2013
    Conway, Arkansas
    Sealing A Crawl Space? Should You Even Have A Vapor Barrier On The Ground?
    There are many today who advocate sealing a crawl space. Even ignoring the very high
    cost of such a project, there are serious problems with such a strategy.But the real question
    “Should You Even Have a Vapor Barrier on The Ground?”
    Nearly every home with a crawl space has a vapor barrier on the ground, but is this really
    the best methodology? Some moisture inevitably comes from the ground, but most of the
    moisture is airborne. To help with this moisture problem the building code has specified a
    certain number of passive vents or mechanical (fans) vents for crawl spaces, but there are
    significant shortcomings with passive crawl space ventilation. Because of this many now
    recommend no ventilation of any kind, not only covering the ground with a vapor barrier,
    but also sealing the walls of the crawl space.
    But there are several problems with sealing the crawl space and having no ventilation.
    The problem is that this sealed crawl space now becomes a closed, stagnant area that is
    never cleaned, so it likely will develop odors and other gases from insect killers, termite
    control chemicals, etc. There occasionally may be dead critters, mice, etc. Any odors, etc.
    in this closed space will migrate into the home's living space, and, of course, the home's
    living space is by far the single most important factor.
    With a vapor barrier on the ground moisture is trapped under it so that the ground can
    never dry out, keeping the relative humidity under there at 100%, 100% of the time. So,
    mold and bacteria is going to grow. Sometimes, after heavy rains, in many crawl spaces,
    there is some standing water most of which is usually contained under the vapor barrier on
    the ground.
    In these crawl spaces that have standing water after a heavy rain, the ground will never dry
    out if a vapor barrier is installed over the ground. In such an environment the water levels
    may increase over time requiring the homeowner to install a sump pump. Keep in mind
    the sump pump will remove some of the standing water, but cannot reduce the relative
    humidity under the vapor barrier.
    Because of termites, when vapor barriers are installed going up the crawl space walls, a
    gap of several inches is usually left open so you are not creating a hidden path for
    termites. Some installers will run the vapor barrier up to the wood rim joist and sub floor
    of the home, but that requires pulling the vapor barrier loose every year to be able to
    inspect for termites, ants, and other insects, then re-attaching the vapor barrier to the walls.
    This annual inspection will not be inexpensive.
    We believe a better method is to not install a vapor barrier anywhere on the ground or any
    wall, to not install any sump pump unless standing water is present all the time, but to install an intelligent crawl space ventilator instead of the usual passive vents. We do
    recommend insulating the sub floor between the floor joists with insulation that has a
    vapor barrier on one side, such as asphalt paper, and that the asphalt paper side is tight up
    against the sub flooring.
    An intelligent crawl space ventilator is a ventilator that compares inside and outdoor
    absolute humidity, not relative humidity. Absolute humidity is the actual amount of water
    vapor in the air. Relative humidity is humidity relative to temperature. Essentially this
    means you might bring in warm outdoor air at 50% relative humidity, and when that air
    cools down to crawl space temperature, the humidity now rises above 90%. defines absolute humidity as the actual mass of water vapor
    present in the air water vapor mixture.
    So, with a crawl space that has
    a. intelligent ventilation
    b. no vapor barrier on the ground
    c. standing water in it after heavy rains
    we see that in a few days the standing water is gone, and the ground is dry, and no mold
    has ever been seen. The benefits of construction over a crawl space without a vapor barrier
    but with recommended ventilation are quite significant.
    1. The home's living space air quality is improved.
    2. If radon is an issue you need to ventilate.
    3. The home's elevated appearance may increase value.
    4. As opposed to a slab the home's comfort is raised.
    5. The foundation's posts, piers, and support pilings can now be dry. Whereas, when they
    were enclosed with a vapor barrier they were constantly kept in a wet environment,
    making them subject to settling or degradation, which would require expensive repair.
    6. The reduced installation costs using this methodology is quite significant, no vapor
    barrier on the ground or walls, plus annual inspection costs.
    7. There are many good reasons why a home ought to be built over a crawl space. The
    elevation may make the home more attractive, plus electrical, plumbing, air conditioning
    modifications and repairs can be done. In addition, almost all structures built on slabs will
    eventually experience some cracking of slab. It's the nature of concrete.
    Dec 2010
    On a Peninsula in NE NC
    Madison, WI/Cape Coral, FL
    Sounds great and will work fairly well as long as you do not cool the mainfloor of the home below the dew point of the air in crawlspace.
    A 1,500 crawlspace with exposed earth will evaporate 4-5 gals of water to the aire above. The source is the water table below the home. If you cover the earth it will be damp in a day from the capillary movement of water up from the from the ground table.
    A material that is below the dew point will be wet including ducts and subfloor.
    Better to close vents and cover earth with plastic. Using a small dehumidifier will give you odor free space.
    Regards TB
    Regards TB
    in a house, Appomattox, Va.
    I heard a lot of blah blah blah, then skipped to the end. sounded like a commercial after read for a bit.
    I've never heard anyone promote a sealed crawl w/o a vapor barrier, dehumifier and handling water intrusion as part of the package.
    radon can be handled same as w/slab- negative ventalition drawn from under the vapor barrier.
    termite inspection is handled by not running the barrier all the way up wall, leaving an exposed section of foundation wall to view. this also prevents the barrier from stopping the wood sill from drying to the inside.
    there's also the energy saving benefit. ducts under house are brought out of outside temps. no frozen pipes. many times the crawl wall has less square footage for heat loss than the floor of house, so less heat transfer even if lower r-value added to crawl walls than would use on floor.
    handling moisture issues in open floor bays under house can be tricky due to temp gradient and dew point vs permeability, as someone mentioned earlier.
    Col 3:23
    Aug 2013
    Intelligent crawl space? Sounds nice but how much does it cost? I know a lot of the pest control companies around here are pushing their service to seal up your crawl space, but who knows how qualified they are. Probably not very.
    Jul 2011
    East coast USA
    the OP makes a lot of sense, but 99% of people who have this issue will not pay the money or have the money to correct the issue..
    during the construction of the home is the time to build a well built crawl space.
    TB's approach is the best and only way to control humidity. You can make some low cost improvements, but unless you start over...there not much else.
    Jul 2013
    Far Away Isle/ Gray Lady - Nantucket, MA
    Hi all.
    The folks over at Building Science Corp. have quite a bit of objective knowledge in this area. They seem inclined towards conditioned crawl spaces. Here's a link to their deep research on the benefits, along with background science, discussion, technique, etc. (
    In my area, coastal, my clients homes would be rotting out from indoors if we'd not designed a solution based on the free, seemingly sound science from Building Science Corp. Different solutions seem to work in different areas I guess.
