+ Reply to Thread
Results 1 to 14 of 14
Thread: Ordering a heat pump system online?
    Jul 2013
    We're almost set to begin finishing our basement and one thing I'm struggling with is the hvac unit.
    We have about 1,200 sq ft to finish and we do want a separate unit downstairs mainly so it's not so cold in the winter.
    We have a GC for the basement build, but I got a few separate quotes for hvac.
    Everyone is saying 1.5 ton heat pump for the space. Quotes are about $ for trane 14 seer unit.
    I really don't want to pay $ for a unit that won't be used that much (in atlanta) if there is an alternative.
    How bad of an idea is it for me to buy the system myself online and then pay to have it installed? I've found multiple places online that have budget line rheem heat pump systems for under $ .
    One person told me installation should run around $ . Is that in the ball park?
    Any other major problems I need to consider? As long as its professionally installed, the dealers say I can send in the paperwork and the warranty is good.
    Prices aren't allowed. In my experience if bought online the manufactures warranty is voided. You have to have an EPA certification to buy charged ac equipment. If I were installing a unit the customer supplied, which I probably wouldn't, I would charge the exact same amount minus what the equipment cost me which would most likely be less than what you pay for it online, so in the end you would end up paying more than if I supplied the equipment. You may be able to find someone on Craigslist to install it but don't expect it to be a quality install or last very long.
    May 2009
    Cumming, GA
    Bad idea.
    No warranty by the manufacturer if you purchase online. They track the serial numbers.
    Good luck finding a good contractor to install this online bought system. Any decent contractor wouldn't touch a web bought unit.
    No pricing info allowed.
    Jul 2013
    Quote Originally Posted by Brent Ridley View Post
    Bad idea.
    What is it that voids the warranty? When I say buy online, it's from a brick and mortar dealer, I just found them online.
    Is the warranty voided if the unit is not sold directly to a professional installer?
    If the warranty is voided, then definitely no deal.
    Jun 2001
    If it's not professionally installed, no warranty.
    SE Ohio
    As Jtrammel stated, you are supposed to be licensed to buy a split system. Only disreputable supply houses try to circumvent those regulations.
    As for potential problems, who will design and install the duct system? Who will cover labor warranty? What constitutes "professionally installed?"
    Here's my position. I am trained, licensed by the state, licensed by the EPA, insured and bonded. I have paid for all the preceding things and I have purchased many expensive tools. Do you think I should work for wages?
    Do you take your own eggs and bacon to McDonald's and expect a lower rate?
    Its voided when sold on the web as far as I know. I seriously doubt you will get a liscenced contractor to install a system you bought on the web, especially for the amount you stated earlier, maybe a moonlighter with no insurance/liscense and most likely not the knowledge to do the job to manufactures specs.
    Jun 2013
    Austin, TX
    1.5 ton is 18000 BTU, about the size of a large window unit. And there's the easy answer: just get a window heat pump.
    Jun 2001
    Why not do a minisplit?
    Neither prices, nor pricing discussion are permitted here.
    Jun 2013
    Austin, TX
    If it's used infrequently, the extra cost will never pay itself back as opposed to a quality window unit.
    Jun 2001
    Quote Originally Posted by NiHaoMike View Post
    Since the OP is mostly concerned about heating maybe plain electric heat would be the best solution? Expensive to run if it's used much.
    Jun 2013
    Austin, TX
    High wattage reflector light bulbs ("heat lamps") are about as efficient as plain resistance heating gets, especially if you really only need the heat in one area. Back when I lived in a college apartment, during the winter, I set the thermostat as low as it goes (just for backup freeze protection in the unlikely event it goes below freezing) and used a 65W reflector bulb as the main heater. It actually got so warm in even a 62F room that I had to put the bulb on a dimmer to throttle it back when I needed to.
    At night, I positioned my PC (a fairly new Athlon 64 at the time) so it blows warm air over the bed to keep my face warm. 150W (Athlon 64 running Folding@Home) all night definitely beats a few kW cycling on for even a short time.
    With Bitcoin, you can earn revenue that "subsidizes" the cost of heat or even net you profit. (It's too bad that where I currently live, heating needs are pretty mild even in the middle of winter and a Bitcoin setup would never pay for itself...)
  14. #14
    Atlanta area
    Homeowners often shop for their first replacement HVAC system by investigating and choosing among various equipment manufacturers, then trying to find someone who will install it cheaply. But they have the cart before the horse.
    An HVAC system is only as good as the installation. If your chosen brand is installed by a poorly trained or a sloppy technician, your system will probably fail years ahead of its time; airflow may be inadequate; dehumidification may be unsatisfactory; you may have drafts; you might have to dust and vacuum more often; you might have mold problems; and you will have a higher energy bill. It's like buying a nice car and putting sugar in the gas tank.
    But if you choose a dealer/installer who does good work, even though he prefers Brand B or Brand C, you will be much happier with the results. Brand B or Brand C might not have the same reputation, but equipment quality is more about perception and advertising than it is about design and manufacturing. And equipment performance is heavily dependent on the ability of the dealer and the installer to design your system and to configure it properly.
    Some manufacturers are very careful about who they will authorize to be dealers of their equipment. Their brands usually have better reputations and better track records than manufacturers who are less choosy. These are often the very brands that have the best ratings in Consumer Reports.
    If you went to the best installer in town and had him put in the cheapest equipment he could get, you would be far better off than if you chose the best equipment and then looked for a cheap installer.
    Vacuum Technology:
    CRUD = Contamination Resulting in Undesirable Deposits.
    CRAPP = Contamination Resulting in Additional Partial Pressure.
    Change your vacuum pump oil now.
    Test. Testing, 1,2,3.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
