Results 14 to 26 of 28
    Southeastern Pa
    Quote Originally Posted by timebuilder View Post
    The only things in my truck that I don't own are the N and B tanks.
    And of course, any recovery tanks!!!!
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Mar 2009
    Mid-Mo
    Add ladders onto that list too.
    Apr 2013
    Independence, MO
    I too have owned and used g5 for years, on very large recovers they are great! My vote also. My next will vac pump will be the tez8. Appion makes great equip.
    Jan 2002
    Palatine Il.
    Personal opinion, your boss wants you to buy it, he needs to help you buy it. AKA buy it on the company account at local supplier, and make payments, automatically withdrawn from your check every week.
    Hi, my name is Glenn, and I'm a Toolaholic!
    Feb 2011
    Peoria, IL
    4 ton and under, stinger 2000, complete recover under 15 min's (again ebay few hundred dollars) wish i had a g5, if you find one for 300 get it!
    Oct 2010
    Quote Originally Posted by ryan1088 View Post
    Another vote for the g5 twin on eBay. Bought mine a few years back for 300 bucks and it's a beast.
    Even if you get one that's "not working" it can likely be fixed for under $100 and they're easy to rebuild.
    Aug 2001
    Mechanicsville, Virginia
    Quote Originally Posted by Frostmonkey74 View Post
    Recovery and Reclaim are two. Completely different things.. ..
    X2
    Definition of terms is one of the very few things one must know for epa certification.
    The G5 is great, the push pull method is great, but even the weakest recovery machine will do an acceptable job if you apply heat (via a heat gun) to the accumulator and compressor and run the indoor fan. Do this while cooling your recovery tank with trickling water from a tap.
    The key to fast recovery is turning the liquid refrigerant into a gas while in the system and from a gas to a liquid while in the tank.
    Atlanta GA area
    Quote Originally Posted by jtrammel View Post
    X2
    Appions are EASY to rebuild, and the factory folks are very supportive. If $$$ is an issue, get an old one and rebuild it. They are more than worth the effort to have.
    GA-HVAC-Tech
    Aug 2009
    Maine
    Bought my first unit in 93 or 4. Bought a G5 last December. Best unit ever and I have had many from then till now, even some home made. The G5 will pay for itself.
    Jun 2013
    Austin, TX
    Quote Originally Posted by penderway View Post
    A friend of mine (former HVAC tech, now a HVAC engineer) sets the recovery tank in a cooler of ice. She even once used dry ice when time was running short.
    A method that does not require making a trip to the nearest grocery store every time might be to hack a cheap window A/C into a recovery assist device. Recover the charge from that, replace the existing evaporator with a spiral of copper tubing that fits tightly around the recovery tank, add a TXV, then find some way to neatly package it. Or wrap the tank in a towel and pour water on it to make use of evaporative cooling, possibly with a fan to enhance cooling on calm days.
    Atlanta GA area
    CPS makes this thing which is more or less a cooler to use in recovery:
    http://www.cpsproducts.com/product/recovery-MT69/
    I put this after the recover pump and before the cylinder... If it is a hot day, put it in a bucket of water. Seems to solve the issue.
    Part costs a little over a C note.
    GA-HVAC-Tech
    Atlanta GA area
    Couple of local supply houses have a free ice machine (fill your ice chest). I use the ice in a bucket for recovery on really hot days.
    Wish we would have some hot days in Atlanta... so far we have yet to reach design temp (92*). We have only had one day in the 90's this year.
    OTOH: Not by any means do I want to work in the SW part of the country...
    GA-HVAC-Tech
    Aug 2009
    Maine
    Making your own unit must be recorded to the EPA. Always had to send in a card when I bought a new machine to register it. What happened to that?
    Quote Originally Posted by NiHaoMike View Post
