Results 1 to 9 of 9
    Jun 2013
    RTAC Condenser cleaning
    Our building has only one chiller, a Trane RTAC 2254, this unit has two refrigerant circuits. Is there a way to shut down one circuit at a time through the CH530 controller so that I can clean one side at a time without losing all my cooling?
    I want to backwash the condensers early in the morning when it is cooler and when it will be cool enough where I might only need one circuit to cool the building. Thanks for any help.
    Dec 2010
    On a Peninsula in NE NC
    I do not reccomend cleaning coils with chiller running. Ciruit locked out or not.
    Jul 2012
    Western KY
    Shut it down and lock it out. Bad things can and do happen when you get after one of these with a water hose while still energized. Do it 3rd shift if you have to but lock it out. Good luck.
    Jul 2013
    Florida
    This is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise, commentary, or ask questions of the OP here.
    Dec 2010
    we have first hand pics at our shop of one of these compressors blowing the peckerhead off after a start up. the fireball was 20ft up and engulfed the underside of the chiller. dont do it.
    and yes you can lock it out from the 530. your choice, your destiny, you have been informed.
    It's hard to stop a Trane. but I have made one helluva living keeping them going.
    Mar 2009
    Mid-Mo
    Quote Originally Posted by Southern Mech View Post
    Wow, that is crazy. That is routine for us to do....
    Aug 2009
    Prattville, Alabama
    I wouldn't have the other circuit running while I was doing the section where you have to crawl under the coils. I don't want that crap and chemicals blowing around me. But I would be ok cleaning the section where you are outside, while the other circuit is running.
    Dec 2010
    We are not allowed to work within reason under a running aircooled.
    S.E. Pa
    Quote Originally Posted by TTer. View Post
    Not certain if you are able to shut it down from 530 panel but if you have techview you can shut it down.
    This is the Ask Our Pro's or AOP forum. In order to post responses here, you must have verified qualifications and have been approved by the AOP Committee. Please see my signature line for links to register and review the AOP Forum Rules. Thank you. Your post will now be deleted. Further infractions may result in loss of posting privileges.
