Results 1 to 10 of 10
Thread: WTF!
    Phoenix,AZ
    WTF!
    Besides the disconnect! This has got to be the stupidest design ever. WTF did they forget to slice the panel in 3 pieces. Or did they not want you fixing it?
    Salt Lake City/Tooele
    Someone must have thrown a brick at the engineers on this. Newer style ones of this model all have separate panels.
    Sep 2006
    Burnaby, BC
    I have never enjoyed servicing those units.
    I do three kinds of work.
    1 - Good - 2 - Fast - 3 - Cheap
    Pick two
    Jun 2013
    sherrodsville ohio
    they have never worked on one in there lives, so have no idea that this is a bad idea, and yes the installer thought this was easier place to put disconnect.
    NH
    Leave it to Carrier...
    Apr 2010
    Winnipeg,Manitoba,Canada
    love the disconnect.
    May 2011
    Western, KY
    Those carriers are a pain, you put your hoses on and now there's a big gap into the duct.
    Phoenix,AZ
    Quote Originally Posted by ryan79 View Post
    I know that disconnect P!ssed me off! This particular unit was a no cool call! Found the return fire damper shut! Pressures and temp about normal if it was 76° inside the conditioned space! But, it was 88°! Found a big hole also in the return past the damper allowing a little bit of hot airflow threw! But, not enough!
    Jun 2002
    south jersey
    Stupid Carrier.
    You need to put the phone down and get back to work!
    Phoenix,AZ
    I got to admit! Carrier has built a good unit before! This relic appeared to be all original! Dual shaft condensor/blower motor finally gave up the ghost after what?42 yrs or so? Owner said to fix it! So i did!
