Results 1 to 9 of 9
    Brooksville, FL
    Plenum loose close to wall
    I have a 7.5 ton Trane air handler in a janitor closet. The tape joint at the plenum is flapping in the breeze on the back side of the air handler. There is only about 2-3" clearance between the A/H and the wall.
    Looking for advice on how to retape/seal that joint. I can only reach about 6" on either side of the A/H and with it leaking the tape is not wanting to restick. Thanks.
    Dec 2008
    Buffalo NY
    Shut the unit off and retape it.
    Sent from my iPad using Tapatalk HD
    Join http://scopeny.org/ Shooter’s Committee on Political Education
    The world is full of sheep,try not to join the flock.
    Support the Skilled Trades, Don't DIY
    Brooksville, FL
    The question is more directed at how do I get tape across the 4' width of the plenum, and get it to stick well, when it is so close to the wall.
    Apr 2006
    Barrie Ontario
    3/8 copper or something similar maybe drive cleet unroll tape to desired length stick to one end, fish behind the unit well keeping it tight to the wall stick to plenum, line up the other side and stick it
    Dec 2008
    Buffalo NY
    Quote Originally Posted by thelmuth View Post
    That is where you have to get inventive.
    FL
    like turkey said. what i do is also double up the tape so its about 3 or 4 inches wide so its more stable when you stretch it out.
    May 2013
    Get a piece of patch metal maybe 24x24 cut a nice hole in the center of the front side of the plenum crawl in and repair/seal from the inside use duct seal not tape. Then your leak is right in front of you and easy to deal with.
    Jul 2011
    East coast USA
    Quote Originally Posted by northeastnewbie View Post
    Thats thinking inside the duct!
    Sep 2006
    Ohio
    Get a piece of duct wrap and slide it between the wall and the duct. Then wrap it around the duct with the seam in the front. If you go over the existing insulation, I think it will keep it from getting wet.
