    AK900 how to calibrate clamp on readings
    Is there a way to calibrate the clamp on readings.
    When I have it clamp on the same pipe
    It has a 5 degrees difference.
    Nov 2011
    East Side
    the clamps don't appear to be as insulated as the velcro sensors.......I think it's because the rubber stays a bit higher temp. than the pipe.
    I checked the pipe clamps and the velcro sensors in an ice bath....they both read almost exactly the same.......so it boils down to insulation.
    I'll try to change the battery on the AK
    Then try it on the ice bath.
    I just had it clamp on liquid line
