Results 1 to 11 of 11
Thread: Loctite
    Feb 2007
    Central NJ
    Loctite
    What type do you use for sealing refrigeration fittings that leak? I've recently used 567. Acceptable? Better versions?
    You have to pay your due's before you pay the rent!
    St Paul, minnesota
    long time ago used to use leak-lock, but don't know if it's still available
    Feb 2007
    Central NJ
    They still make it. Will not use it. Mine as well use hydrolic cement
    NH
    I use loctite 567 as well... I Try not to use leak lock for anything now a days.
    Jun 2009
    South Carolina
    went to one today where. at one time or another there was leak lock put on the where the piston is at in the ah. needless to say there is a restriction in the indoor coil and i could not blow it out with nitrogen.
    And damn leak lock was so tight i twisted the dam copper trying to break it loose f***.
    Oct 2010
    Nylog is where its at!
    Feb 2007
    Central NJ
    Quote Originally Posted by jtrammel View Post
    I agree, but certain applications call for something a little more heavy duty. Had a couple of maytag service valves leak profusely ( they were wrenched, over heated during brazing or both). Slapped some 567 on em, sealed right up. Plus I don't believe it hardens or cures like leak lock
    Feb 2007
    Fremont, Indiana
    I second this.
    I should buy stock
    sent from my Samsung Galaxy Note
    Member of the "Work Exchange Program"
    "Will work for knowledge"
    "Everyone is a genius. But if you judge a fish on its ability to climb a tree, it will live its whole life believing that it is stupid"
    A Einstein
    NH
    Nylog is great for gaskets and flares and rubber o rings... But with indifferent threads like brass to steel I'm using loctite 567.
    Oct 2012
    Where we mow our own grass
    I've used Leak-Lock, Loctite 567, Loctite 554, and Nylog, on threaded fittings.
    If you use Teflon tape at put Nylog over it, it seems to work.
    Leak-Lock works real good, but is difficult to get apart.
    Loctite 554 takes forever to cure, and is difficult to get apart.
    Loctite 567 seals real good, and is easy to take apart.
    Feb 2005
    I like Loctite 515
