Results 1 to 13 of 19
    Does anyone know what W stand for with heat on the circuit board?
    Like w is for heat and Y is for cooling
    What is the reason W is used to indicate heat?
    Practically Canadian ehh.
    This may sound naive but I always assumed the letters stood for the colors used: Red Green Yellow White
    Dec 2003
    SLC
    I don't know what it stands for, but I do know that Honeywell created the R,W,Y,G,C terminal designation years ago.
    NW AR
    I thought it was wire color too.
    Feb 2005
    Where it's dark & damp
    I don't know what it stands for but I remeber working on some old York package equipment that had different terminal designations. I thought the old designations made more sense than the current ones. I believe it had a F for the fan but don't remember the others. If it weren't for one of the units still having a wiring diagram I wouldn't have known what the terminals stould for.
    Nov 2005
    Yes there are some older equipment that does not use the standard wiring colors we are use to.
    Atlanta GA area
    I am not sure if this was smoke or not, but this is what I was told at a Trane tech school:
    The instructor is in his 60's, an old marine. He said that back when central ducted forced air was ONLY heat, there was a two wire line to the millivolt (remember those) thermostat. The colors of the wire were red and white. So since red is always power, then white became heat by default.
    I have seen a lot of folks that use the blue for cool (put blue on the Y terminal).
    I really do not care which code folks use, as long as they use the SAME code all the time. Makes it a lot easier to trouble-shoot things.
    GA-HVAC-Tech
    Earth
    Quote Originally Posted by ar_hvac_man View Post
    What color is C?
    Atlanta GA area
    Quote Originally Posted by frozensolid View Post
    What color is C?
    Trane or Rheem/Ruud?
    GA-HVAC-Tech
    Fort Worth, TX
    Quote Originally Posted by ga-hvac-tech View Post
    I always loved it when there'd be one set of wire colors on the roof, and when you got to the stat down below, things changed. Somewhere midway a hidden splice, with colors switched mid-stream to make the tech's day all that much more fun.
    Also loved how Lennox would use different designations for their low voltage. Also made things fun. Personally I like when the colors are literally followed along with what each terminal stands for.
    Building Physics Rule #2:
    Building Physics Rule #3:
    CHICAGO SUBURBS
    I know what you mean Shophound, I had a RTU call once at a medical office. Dead of chicago winter. Frozen evap coil. Get it thawed out and check low volt wiring. 4 wire R,W,G,B instead of Y but it's all good as I use this 4 wire type myself. RTU was wired correctly but at the thermostat someone put the blue wire on the blue terminal. uh oh. I fixed it and told the nurse what was wrong only to get chastised by her because her hubby installed that and he is a Union electrician and can surely install a simple stat. What can I say but when I arrived it didn't work and now it does.
    Some people swear by me and some at me
    Atlanta GA area
    Yeah Tim, it never ceases to amaze me that electricians know more about the INTERNAL wiring of an HVAC system than a licensed HVAC guy does...
    Kinda like liberals and politics and life... But I digress...
    GA-HVAC-Tech
    Amory Mississippi
    yeah like the elctrician that wired a couple air handlers. Split the two blacks to each leg coming in and ran the two yellow right to ground. hmmmmmmmm
