Results 1 to 13 of 23
    Jan 2013
    SMAN 4 GOING THE WAY OF SMAN 3?
    The boss bought an Sman 4 for himself and one for me early this year. Summer came way late and ours SMANs did not see much usage until the past two or three weeks.
    Bosses SMAN started leaking by from the hi side so FP sent him a new one 2nd day air. Now this one was is leaking by too. To say the boss was pissed is an understatement. He called FP and pretty much was not taken very seriously by the tech. No solution was was offered by the the tech.
    Boss called the next day loaded for bear. Got another tech who explained that the new SAMN 4s have a different valve gasket that needs to be torqued down tighter than one would usually consider to make a leak tight seal.
    Uncle is admittedly a tough customer but the treatment he received
    from FPs first tech was un-deserved. Our company has been a strong supporter of FP even when the our instruments did no perform as advertised.
    We will continue to support FP but I feel this incident needed airing.
    Also we are on FP email list. A service bulletin should have been issued on the new gaskets in the SMAN 4. Boss was also informed they received a small number of SMAN 4s back for this reason.
    Just thought this was important enough to inform others who might have had the same problem.
    In a machine room
    Too bad you can't mount them on your choice of manifold.
    Worry is a really gross misuse of one's imagination. -- PHM
    Oct 2007
    Anaheim, CA
    Quote Originally Posted by hvac5646 View Post
    Sorry to hear you/your boss had a bad experience the first time around. I hope Uncle felt better and is back at it with his SMAN after the second time around.
    We appreciate the feedback...we know we aren't perfect and can only get better if someone calls us out when we stray off course!
    Cheers
    Travis
    Jan 2013
    Quote Originally Posted by chuckcrj View Post
    I don't get what u mean. You do know that Uncle and I both own Ak 900s as well as Testo digitals, don't you? So inferring that Uncle should buy a DC is pointless since already owns two.
    In a machine room
    I wasn't inferring that you should buy a DC. I knew you had one.
    Jan 2013
    If you mean it would have been nice to have the option of mounting the SMAN to a diff manifold, it probably crossed Uncles mine.
    If i confused your meaning I apologize.
    Jan 2013
    Quote Originally Posted by ault51 View Post
    Cheers
    Travis
    So far so good.
    In a machine room
    If you mean it would have been nice to have the option of mounting the SMAN to a diff manifold....
    Yes, that would be a nice option.
    Jun 2009
    South Carolina
    Right when i was about to buy one. I may hold off a month or two now to see if this is going to be a major prolem
    Feb 2007
    Fremont, Indiana
    Yep
    Same here!
    They sent me new valves. When I pulled the old ones, I didn't see anything wrong with them. I reassembled with nylog.
    I found the problem is that you have to crank the crap out of them to stop the leak-by.
    sent from my Samsung Galaxy Note
    Member of the "Work Exchange Program"
    "Will work for knowledge"
    "Everyone is a genius. But if you judge a fish on its ability to climb a tree, it will live its whole life believing that it is stupid"
    A Einstein
    Feb 2011
    Peoria, IL
    who in the hell is "uncle" or im i missing something, i should be getting?
    May 2012
    Upper Michigan
    Quote Originally Posted by garychance View Post
    It's his uncle/boss
    Jan 2013
    GREAT.
    Today MY SMAN 4 started leaking by. WTH? We have some spare upgrade valve kits from our SMAN 3s. Gonna try that and see what happens.
