Results 1 to 9 of 9
    Jan 2006
    Bryant AR.
    Anyone know what this is?
    I am trying to find out what this unit is,
    Model # NAXCA02AH01
    Serial # Y60751368
    There is no nomenclature on the unit and compressor tag has been removed.
    Whirlpool,Hiel ,Sears,etc.
    Model number looks wrong,can't tell the size.
    Thinking Temstar,Comfortmaker,has a replacement that is same/similar.
    South Jersey
    I remember working on a couple of those about ten years ago. Usually mounted to a mobil home. Oddball brand, will try to remember.
    It Is What It Is
    east central indiana
    An old Heil-Quaker product. Model number doesn't make much sense to me either. I guess you'd contact ICP for info.
    This space for rent.
    There's a digit missing, probably ...024AH01
    Hell Hole Swamp
    The supply and return are backwards on those compared to most other units, that will be a problem when replacing it if you use another brand
    May 2005
    Grand Rapids, MI
    The model number you are giving is for an optional electric heater accessory for this unit. It is a 9.6KW 240 volt heater element. This is commonly listed on package units used for mobile homes to be used as backup if you are running the unit as a heat pump or if you desire electric heat.
    Look closer. You should find another model number somewhere. NPH , NPA, NRG, NRL Those are the most common prefixes for this one.
    Northen West By God Virginia
    Frown
    ICP Heil still make that style of a/c or heat pump.
    Myrtle Beach, SC
    What he said. Still see a lot of these around. Used mostly with low budget customers. Supply & return duct connections are backwards from most other brands. Low air flow problems common.
    Remember, Air Conditioning begins with AIR.
