Results 14 to 25 of 25
Thread: Cleaning
    Jun 2013
    orange county, ny
    try simple green..i'd like to now if it works... it should work great and ur eyes wont burn from the fumes
    May 2013
    near knoxville tenessee
    triple d mixed with really hot water. The grease drips right off.
    Apr 2010
    NYC
    Been there, I use what ever the restaurant uses to clean the greasy pans.
    Customer is alWays opposite of Left
    Stongsville Oh
    You are right about dilution, I meant to say but didn't that on some very greasy dried on stuff I have used it full strength and let it sit then flush a lot. This is a rare occasion. It is also kind off expensive to use wrong. I stand corrected.
    ckartson
    I didn't write the book I just read it!
    maryland, baltimore
    We had a really nasty kitchen, fryer was 6' from refrigeration units, everything was wet with grease. I used one of the spray can condenser cleaners and nearly shutdown the kitchen, the stuff removed the oil but left a hard film on the coils. They had Dawn soap in the kitchen, so I tried it and it got the coils clean and it left a residue that would not allow the grease to adhere to the very old steel coils. No offensive odor or food contamination.
    Dec 2012
    Lowell,MA
    i have used used evap foam cleaner in the aerosol can and pump sprayer to flush out after foam breaks, just keep the shop vac running so you don't get water everywhere
    Dec 2012
    Lowell,MA
    i have used used evap foam cleaner in the aerosol can and pump sprayer to flush out after foam breaks, just keep the shop vac running so you don't get water everywhere may need to do it a few times but it works
    Southeastern Pa
    Viper is good stuff.
    Checkout there YouTube video.
    You mean this one?
    http://www.youtube.com/watch?v=o9TVMcqZ69U
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Jun 2013
    NORTHERN
    Quote Originally Posted by hvac69 View Post
    I have used oven cleaner and then washed with water in the past.
    and rinsed for 10- 15 min I hope , if it is that restaurant heavy duty that an owner took out his condensers on two stores without enough rinsing.
    I use refrigeration biodegradable 4:1 as on bottle and it really works well, no acid.
    Dawn is great for puncture wounds too and soaking cuts 30% to 70% water !- just like the doc used before 5 stitches went in to my palm
    Jan 2010
    Probably was supertech who first posted it.
    Jun 2013
    NORTHERN
    Those spray in can blasters work if you wear a painter's filtering face mask to never inhale...
    I have followed up with either a small compressed air, or CO2 blast (use appropriate safety nozzle)
    Jun 2013
    NORTHERN
    watz a supertech , VT?
