Results 1 to 13 of 25
Thread: Cleaning
    Michigan
    Cleaning
    I have the luxury of having two Tecumseh Condensing Units [< 1/2 HP] in my shop. They both suffer from an extensive case of "kitchen grease" contamination. I do realize, that they can be power washed, and if I am lucky enough to find a steam cleaner, and there is always the "elbow grease" method of using a cleaner such as Cal-Clean HD.
    Does anyone have another alternative cleaning method that is really good....???
    maryland, baltimore
    dawn dish washing liquid and hot water
    Dec 2012
    columbus, OH
    Cleaning
    Not sure of its effect on aluminum but mean green degreaser does a great job on grease.
    Aug 2009
    Maine
    And steam will help might be just the way to find a leak the you have never noticed before.
    SE Pennsylvania
    I have used oven cleaner and then washed with water in the past.
    Jun 2013
    N. Canada
    Carwash
    Oct 2011
    Chicagoland Area
    Nubrite, hot water and a condenser brush
    Jan 2010
    Quote Originally Posted by 2sac View Post
    Yep...on aluminum you can't beat it.
    Jul 2011
    Nanaimo,BC, Canada!
    Viper coil cleaner , and a garden hose... A pressure washer would work great if you can get it out side..
    Stongsville Oh
    I like calclean hd. May want to use it full strength. It is a good detergent.
    ckartson
    I didn't write the book I just read it!
    Quote Originally Posted by Frostmonkey74 View Post
    Viper is good stuff.
    Haven't seen the one called Renewz in a while, but that was an awesome cleaner, too. Of course, it would remove fingerprints if you got it on your hands, so maybe it was a little corrosive.
    Jan 2010
    [QUOTE=jpsmith1cm;16088911]
    Checkout there YouTube video.
    Oct 2009
    Raleigh, NC
    Quote Originally Posted by ckartson View Post
    You should dilute Calclean, and most concentrated detergent cleaners, at least some with water. They actually work better this way.
